View unanswered posts | View active topics It is currently August 13th, 2025, 4:16 am
Reply to topic  [ 22 posts ]  Go to page Previous  1, 2, 3
 How well do you know 2cvs you should take a test!
Post Re: How well do you know 2cvs you should take a test!
4x4 SuperFinn wrote:
They arent fully independant, if you look at the end of the spring tube, there's a rubber bush about 3" diameter, that allows the spring tube (with 2 springs inside) to move back and forth a small amout, which reduces the pitching motion (i think) and although the movement is very small, it is still technically independant.
But the bush is not there on vans, (Amis I think),and Barbour 4x4s
Ami8 and AKS400 July '76 onwards, all Ami Supers, and all Acad.s lack the rubber 'doughnuts', rendering the suspension fully independent. All the others, with doughnuts, are independent but interconnected.
The anorak cometh...
March 20th, 2009, 1:36 am
Thanks for the clarification...
March 20th, 2009, 9:41 am
