View unanswered posts | View active topics It is currently April 29th, 2026, 5:07 am
Reply to topic  [ 23 posts ]  Go to page Previous  1, 2, 3  Next
 Side exit exhaust
Post Re: Side exit exhaust
Justint wrote:
just ordered one form ecas, I am so keen on the idea
How old's the torpedo & swan-neck? Separating those sliding exhaust joints can be a RIGHT pain...
June 6th, 2010, 6:17 pm
agreed, buy it all at once.
June 6th, 2010, 6:21 pm
my main exhaust looks brand new so should be ok
Charlie is gone. Now 2CVless.
June 6th, 2010, 7:13 pm
I have one, and aside from the odd blast of exhaust gas into the cabin if the door is slightly ajar its not problematic.
June 6th, 2010, 9:12 pm
Like all the previous posts, I've run short pipes for the best part of two decades with no problems.
June 7th, 2010, 7:30 pm
If I use zip ties I assume I wrap them around the rubber hanger? They will melt of that touch the exhaust wont they?
June 25th, 2010, 10:13 pm
No. The zip tie stays on the outside of the rubber.
June 25th, 2010, 10:34 pm
Thought so, thanks. Although I may try to do it better and use an additional braket.
June 25th, 2010, 10:40 pm
I'm running a more extreme version of this, mounted a van backpipe on the the pipe coming from the engine bay, so my 2. silencer is gone, my first silencer also!! But I'm cheating a little bit because it's a turbo engine and the turbo silences the exhaust (a little).
http://www.youtube.com/watch?v=5aTO2LkTkpM
The end of the exhaust is underneath the frontdoor!!!!
You can feel the exhaust blowing but it's to cold to really burn your leg (my opinion)
June 25th, 2010, 11:50 pm
Joe Ahvee wrote:
short pipes down fill up with water causing the second silencer to rust through either. i find.
If you jack the car up and drill a small drain hole ,say 4 or 5 mm diameter ,at the lowest point of the torpedo at the bottom front end of it just before it tapers down into the front joint that problem
(which is condensation ,nothing to do with short tailpipes) is solved.
June 28th, 2010, 12:16 pm
