View unanswered posts | View active topics It is currently April 29th, 2026, 3:54 am
Reply to topic  [ 5 posts ]
 acadiane drivers door lock
Post acadiane drivers door lock
The push button on my acad drivers side door lock has broke. On removing the door panel I have noticed a small spring has broken and this is what returns the push button to it's original position. My problem is I can't seem to get the lock out of the door itself to have a proper look. Do I have to remove the whole window mechanism to get it out(it has posh wind windows).
cheers
ps all this hassle for a 20p spring :roll:
June 6th, 2010, 4:11 pm
Post Re: acadiane drivers door lock
Had the exact same problem on mine, Graham. The spring snapped & the button did nowt & i couldn't keep the door shut.
I ended up drilling out the 2? pop rivets the hold the window channel to the frame, then removing the glass. I think the problem was i couldn't undo one of the two nuts that hold the handle to teh skin. Whether or not this is the best way to do it, i don't know!
June 6th, 2010, 4:25 pm
ok cheers Neil. where did you get the new spring from?
June 6th, 2010, 8:07 pm
My dad. :lol:
Although, i've got two Dyane front door lock mechs sat on the shelf in the shed, which i forgot i had until after he'd hunted high & low trying to find a decent spring. :roll:
If you get stuck, let me know & i'll stick one in the post.
June 6th, 2010, 8:12 pm
sounds like a top dad :D and thanks for the offer I'll let you know ;)
June 6th, 2010, 8:53 pm
