View unanswered posts | View active topics It is currently February 3rd, 2026, 12:56 pm
Reply to topic  [ 16 posts ]  Go to page Previous  1, 2
 Cooling fan keeping it's teeth?
Post Re: Cooling fan keeping it's teeth?
will get some
May 31st, 2010, 10:10 pm
Just took a good look at those Magnetic clutch fan pics......thanks Spanners.....some really nice work there. 8-) 8-) 8-)
May 31st, 2010, 10:23 pm
it goes via the brain on mine because its a visa so you could just take it from a power source, fuse, switch ect
June 1st, 2010, 10:58 am
OOOOHHH :!: That is sweet...... 8-)
Do you have any overheating issues or battery charging issues?
I love that arrangement,very neat.
June 1st, 2010, 12:48 pm
no battery charging problems the altenater drive belt goes to a cut off I guess drive bit cant get my camera in to show you :?
June 1st, 2010, 1:27 pm
Fitting cylinder temp guages is useful when fording. If the fan goes you'll know as you'll see the temp go up.
I used a C15 fan for a bit but had to give up as on road on hills the temp went up to 200c so I was forced to a crawl. Resorting to the standard fan brought the temp back down by 40c and I could go flat out.
June 11th, 2010, 11:57 am
