View unanswered posts | View active topics It is currently April 29th, 2026, 1:15 am
 Sidewinder
Post Sidewinder
Just curious. I understand that a 'Sidewinder' is the name given for a 2CV/Dyane fitted with an 1100cc/1300cc Ami engine. How easy is it to fit to a 2CV?Dyane (presumably as it's a four cylinder engine, it'll project further into the front?), and is it usual for the combined engine/gearbox from the Ami to be fitted or will the Ami engine happily mate with the 2CV/Dyane gearbox?
I've no interest in modifying mine but simply interested.
May 19th, 2010, 11:37 am
Post Re: Sidewinder
I'm sure someone who knows more than I will be along shortly... but as far as I'm aware, it's not just a case of fitting a GS/GSA engine to a 2cv. In general, they're body swaps - putting a 2cv or Dyane shell onto Ami super running gear. Which gets you a stronger chassis, designed for the flat four, and anti roll bars and stuff.
I think most folks use the ami super 4 speed. I think the GS 4 speed is larger, and I'm sure the 5 speed is.
Seems to fit nicely on a Dyane, 2cvs need some work. The original "Sidewinders" had an "interesting" bonnet bulge thing. Or you can do things with fibreglass - like on Tim's van...
I've seen a 2cv with a GS motor, where some subtle cutting of cowling and wings had squeezed the motor in, leaving things looking pretty much stock. Which was nice...
May 19th, 2010, 12:03 pm
Post Re: Sidewinder
GS motor tends to require a stretch at the front end a little...
May 19th, 2010, 12:25 pm
Post Re: Sidewinder
My old Sidewinder Van was Ami Super Chassis, Acdyane body, GSA1300 engine, and 5 speed GSA box with a bit of rust thrown in.
I did the engine and box change once which was easyish as the work had been done before but to start from scratch the issues as I see them would be getting the wiring loom right so it runs, cooling the brakes so it stops, getting the drive to the wheels as a GSA box uses different driveshafts.
Making it look neat on the outside is up to personal preference!!
May 19th, 2010, 1:26 pm
Post Re: Sidewinder
Yup. Bigger springs, non-interlinked front-rear suspension etc. Generally far, far beefier. The G motor fits very differently, too - the engine mounts are at the rear, where there isn't normally a crossmember on a 2cv chassis, and the exhausts are under the heads.
The 5spd has a bit more protruding to the rear. The Ami & G 4-spds are the same casing, but the Ami has a shorter bellhousing and input shaft.
May 19th, 2010, 5:28 pm
Post Re: Sidewinder
Been there, had one, got the T shirt. there's no point any more. Joolz proved that to us all last week. In it's time, yes, the best way of making a 2cv fast, but simply finding the parts nowadays is a hassle.
*This* is the way forward:
May 19th, 2010, 6:56 pm
Post Re: Sidewinder
A BMW R-series 'oilhead' 1100/1150/1200 engine presumably attached to the 2CV gearbox. Any probs with that? Very good engines. :)
May 19th, 2010, 7:34 pm
Post Re: Sidewinder
BMW 1150, mated to a Citroen LN 'box.
May 19th, 2010, 7:45 pm
Post Re: Sidewinder
Isn't sourcing gearboxes going to be a problem? Are there enough suitable ones about?
May 19th, 2010, 7:54 pm
Post Re: Sidewinder
seems to be just it'll cost a bit and more seen as some hooligans in 4x4s keep blowing them up.
May 19th, 2010, 7:59 pm
Users browsing this forum: No registered users and 105 guests
