View unanswered posts | View active topics It is currently April 28th, 2026, 11:57 pm
Reply to topic  [ 10 posts ]
 Help Headlights won't work on dip
Post Help Headlights won't work on dip
Hi thanks for the help last week on bad egg smell. It turns out I needed a new voltage regulator the battery was being fried. However the healights now won't work on dip. I have replaced all the bulbs, the back lights side lights and everthing else works. Full beam works but if I put on dip no headlights. Any ideas please ;)
May 1st, 2010, 12:22 pm
Post Re: Help Headlights won't work on dip
Could be your stalk - try wobbling it around and see if they come on then - also check the screws that hold the cables on to the stalk .....I cant remember if there is a relay in the dip circuit but if so that could be faulty....SSD
May 1st, 2010, 12:29 pm
If your car is a late model 2cv (post 86), a likely reason is the dim-dip relay(you'll have two relays on the bulkhead next to the battery, it's one of those). The general consensus is that the dim-dip system should be binned(it's a cause of much grief).
May 1st, 2010, 12:50 pm
Do I need to replace the relays then? its an E Reg
May 1st, 2010, 12:57 pm
Do a 'Search' for the dim-dip issue. Ken's accurately described what to do to modify the system, and what to chuck away. I followed his tip and everything works fine.
May 1st, 2010, 1:04 pm
Take a look here.....
viewtopic.php?f=7&t=1361&start=30
May 1st, 2010, 1:05 pm
:lol: I nearly posted a thread on this myself.
I'm on my third lights switch this year (broke first one, connections died on second)
I've binned the whole dim-dip thing
All my bulbs are frin.
However I have intermittant dip beam.
Turn engine on, flick from high to low beam... nothing... wait a few secs... and dip beam comes on :?
Sometimes i think going over a bump helps turn them on, however I may be imagining this.
Any ideas :?:
May 1st, 2010, 1:09 pm
Thanks played around with the relays and managed to get the lights working.
:D
May 1st, 2010, 1:33 pm
Any ideas :?:
mine did this when the contacts wore out on the barrel in the switch. but might be worth checking the connections on the light bar. as my lights flickered a bit until i cleaned all the contacts up a bit. oh and re-connected an earth wire too ha
May 1st, 2010, 3:21 pm
@ sam I had this i just followed the wires and found one that was loose and sorted it out, job done.
May 1st, 2010, 7:54 pm
