View unanswered posts | View active topics It is currently February 3rd, 2026, 12:38 pm
Reply to topic  [ 538 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8 ... 54  Next
 Joolz's Red One
Post Re: Joolz's Red One
Thanks, and if you could overlook the gaping hole in the rear panel immediately underneath them that would be great. :roll:
April 28th, 2010, 10:15 pm
Consider it done.
April 28th, 2010, 10:30 pm
Joolz wrote:
Maybe I've got too much time on my hands or maybe I'm just trying to avoid doing anything useful. But for some reason I removed the writing from my rear lenses
You have your priorities right then :lol:
Low and Loud!
April 28th, 2010, 10:50 pm
It's a familiar scenario, titting about with something unnecessary to avoid the difficult jobs.
April 28th, 2010, 11:02 pm
Alright, so something slightly less pointless today. Uprated shocks, this is based entirely on instructions originally posted by pete sparrow.
I had a rummage around through my spares to pick out the two best rear shocks, and cleaned the gunge off them.
After cleaning up the relevant area with a wire brush, I drilled a 9mm hole 20mm along from the dimple that indicates the top.
Followed by emptying out the oil into a measuring beaker, hopefully taking any swarf with it. It was a bit black looking.
It took a bit of effort to work all the oil out of the shock, but once it's out the shock can be compressed quite easily. I got 230ml of oil out of one and 240ml out of the other, I can't explain the difference, they were the same make but not a pair.
Next I welded 8mm nuts over the holes, welding one flat of the nut at a time and cooling the shock body with a wet rag in between. This is TIG welding, it's slower than MIG so makes the shock hotter, but it easier to get a good seal, and it looks nice.
Refilling the shock was made quite easy thanks to a large syringe body which fitted perfectly onto the 8mm nuts. With the syringe filled, extending the shock sucked the new oil into the body while compressing it blows bubbles of air back out. The oil going in is 80w90 gear oil and was measured in the beaker to make sure that the same amount went back in as came out.
Once the shock is full again it's very hard to compress and a short bolt and copper washer seal it up.
Now all it needs is a coat of paint and we're ready to fit.
May 2nd, 2010, 12:58 am
Good work!
May 2nd, 2010, 1:22 am
really neat job - good work
May 2nd, 2010, 9:02 am
Tidy!
May 2nd, 2010, 9:26 am
I need to learn to weld like that!
May 2nd, 2010, 1:05 pm
gym bunny
you put the rest of us to shame... :( Think I need to get some skill!
1299cc FTW
May 2nd, 2010, 2:09 pm
Users browsing this forum: No registered users and 286 guests
