View unanswered posts | View active topics It is currently May 1st, 2026, 10:46 am
 speedo file
Post speedo file
so I put a new speedo cable on,it works but now has a lovely ticking sound that will drive me mental by the time i get to England
anyone got a cure (and the radio/cassette will not turn up loud enuff to cover it)
its a new cable and has no tight turns in it
help
April 20th, 2010, 9:16 pm
Post Re: speedo file
lube?
April 20th, 2010, 9:19 pm
grease or wd40? or vaseline
April 20th, 2010, 9:21 pm
I'd try taking it out of the speedo and refitting it, maybe it's not quite in right?
here's a man, and his Speedos.
April 20th, 2010, 9:35 pm
East siiide hand gesture? and does that cross mean that he is part of the catholic church? because it would make a lot of sense if he is.
April 20th, 2010, 10:11 pm
:lol: Hahaha best topic title ever :lol
Low and Loud!
April 20th, 2010, 10:21 pm
help
New, you say? Does the needle jump in sympathy? If so it sounds like it's kinked to me
April 21st, 2010, 5:34 pm
I reckon it is more than just a lube issue, and better sorted sooner than later (each click could be more damage done, EEK).....If you do want to try lube though, use a graphite compound.....nothing does it better (used graphite for years on flex drive drills....1000's of hours and lots of stress and angulation, never wore a shaft out yet)
Best of luck,
Shane.
P.S.-That guy is definately a priest, I think that is the standard issue, beach dress no.2 banana hammock he's wearing, ........shudder :shock:
April 24th, 2010, 5:05 pm
you deserve everything you get, ya flash bastid.
April 24th, 2010, 9:21 pm
Doesn't a ticking mean the rear Gearbox bearing could be failing?
Mine did b4 it locked up in peak-hour and rammed the rod through the rear housing... I though it was well rooted but my 2cv man fixed it all with engine and gearbox still in car;)
was a ticking with an occasional fluter/bounce which i just thought was character...
April 26th, 2010, 3:07 pm
Users browsing this forum: No registered users and 79 guests
