View unanswered posts | View active topics It is currently April 29th, 2026, 12:15 am
 Petrol and Diesel
Post Petrol and Diesel
STUPID BOY :shock:
So just went and filled up the AUDI A2 TDI (DIESEL) and put 38p worth of unleaded in it before spotting that I picked up the wrong nozzle - filled it and over filled with about £28.00 worth of diesel - Should be ok - what do you all think?
March 15th, 2010, 11:43 pm
Post Re: Petrol and Diesel
we used to put a gallon of petrol in our wagons at work in the winter to stop the diesel freezing, so I think you'll be ok with 38pees worth, which at current prices will be half a thimblefull.
March 15th, 2010, 11:53 pm
38p... About a mouthful...
It's a PD engine, rather than common-rail, so it's not going to be quite as horrifically expensive if it does all go south - the high-pressure pump is built into the injectors. Mind you, the injectors are FEROCIOUSLY expensive... A quick google suggests new 'uns are the thick end of five hundred quid. Each.
If you've already started it since, it's academic!
Ginger - that'd be before common-rail. You really, really, really don't want to muck up on one of them - instead of fuel pressures around 3bar on a normal petrol injection, they're running at anything up to several THOUSAND bar injection pressures... Those are seriously scary tolerances in the pumps.
March 15th, 2010, 11:57 pm
I put 4 3 liters of Diesel in the 2cv once. There was smoke. Lots of it. For a while.
So I kept topping her up with Petrol and she was fine after a day or so.
March 16th, 2010, 12:19 am
It had new injectors about a year ago - rrp. £700.00 each!!!!!!!,
Im driving up north tomorrow - so we will see!
March 16th, 2010, 12:22 am
Could be worse. At least there's only three of the little buggers.
I've always quite liked the A2.
March 16th, 2010, 12:38 am
All good today, did 300 miles then filled it up again - this time with diesel :roll:
March 16th, 2010, 7:27 pm
Old Bloke
:o
Now known as 602
http://www.2CVTech.co.uk
March 18th, 2010, 1:09 pm
grifftravel wrote:
:o
Why?
It's a technically unorthodox attempt to do something _different_ in a horribly dull market segment. Something we could do with more of in new car showrooms...
March 18th, 2010, 1:14 pm
Old Bloke
toomany2cvs wrote:
grifftravel wrote:
:o
Why?
Its never sold very well though has it, I wonder why. Saw a DS3 in the flesh last week. I am impressed, it really does look different.
Now known as 602
March 18th, 2010, 1:48 pm
