Author |
baron_matt
Joined: January 24th, 2010, 12:22 am Posts: 386 Location: Buckinghoonshire
 Re: Speed Loss
Louise wrote: Max...I didn't know you were going in the van i dont feel so bad now  Paul...They would get shouted at yes but they would be fine without me lol It sounds daft but have you checked the obvious stuff. Tyres at correct pressure and not flat. Brakes not binding no air leaks on carb (is the lid screwed down etc) Good clean Air filter in? Nothing loose or about to fall off etc good fuel in the tank? Have you done anything to it since it went up the hills well? In it tonight?
_________________ 1973 Ami 8 Club 1977 2CV6 Belgian built RHD blue
March 9th, 2010, 4:32 pm |
Louise
 Re: Speed Loss
Max...I dont get that photo  Matt yup i'm in it tonight but it will be dark haven't touched it (i don't tend to) so maybe ill get someone to have a looky before france
Registers Day Winner 2008 and 2009... Betty died before the masterclass
March 9th, 2010, 5:40 pm |
Will2cv
 Re: Speed Loss
A bit of background info. The engine in question has had, in its recent past, its heads re-torqued and valve clearances set and runs a 123 ignition which is also correctly set. Compression is good, carb nuts all tight (or at least they were) and no obvious air leaks (inlet manifold bolts all tight etc). All this was a fair few thousand miles ago by now though so things could have changed!
Betty has displayed the symptoms of overheating in the past though, it sounds like it has maybe got a bit too warm again for some reason?
Might be worth checking the oil cooler for gunk buildup and iirc the engine has always had a fairly sizable 'flat spot' too so trying a different carb might improve things.
1979 2cv6 (Evie) 1983 Beachcomber (Mavis) 1974 AZU250 Belgian PO (The van) 1991 AXGT Mk1 2008 C5 2.0 HDi VTR+
March 9th, 2010, 5:56 pm |
Little Louis
 Re: Speed Loss
Louise wrote: Max...I dont get that photo  Its a gs 4 cylinder engine.
March 9th, 2010, 6:13 pm |
baron_matt
 Re: Speed Loss
Will2cv wrote: A bit of background info. The engine in question has had, in its recent past, its heads re-torqued and valve clearances set and runs a 123 ignition which is also correctly set. Compression is good, carb nuts all tight (or at least they were) and no obvious air leaks (inlet manifold bolts all tight etc). All this was a fair few thousand miles ago by now though so things could have changed!
Might be worth checking the oil cooler for gunk buildup and iirc the engine has always had a fairly sizable 'flat spot' too so trying a different carb might improve things. Yeah lets have a gander and see if anything has obviously fallen off/gone wrong. Oil cooler might be clagged up or the breather might be shot. might just be nothing to worry about like crap fuel. Stick some super unleaded in it and see what happens.
March 9th, 2010, 6:48 pm |
Louise
 Re: Speed Loss
Might be worth checking the oil cooler for gunk buildup and iirc the engine has always had a fairly sizable 'flat spot' too so trying a different carb might improve things. Haha wanna come fix it seems you know the most about it
March 10th, 2010, 11:10 am |
grifftravel
Old Bloke
 Re: Speed Loss
Lou
_________________ Now known as 602
http://www.2CVTech.co.uk
March 10th, 2010, 12:19 pm |
Louise
 Re: Speed Loss
I was always told if you don't ask you don't get
March 10th, 2010, 2:15 pm |
Users browsing this forum: No registered users and 277 guests |
