Time to put a 2cv to sleep for a bit !
Author |
oboe
Captain Slow
Joined: January 14th, 2009, 5:36 pm Posts: 230 Location: some where in the world
As some of u know im of overlanding it to Australia in april  and then stopping in Oz for a year or two so slowboe is going into storage in a dry garage what i want to know is , do i just drive it in and shut the door or is there a few things to do on it ??? it may cum out to play for the french world meeting cheers Oboe
March 4th, 2010, 6:49 pm |
Neil
 Re: Time to put a 2cv to sleep for a bit !
Drive it down to Louis' workshop, so when you come back and collect it for Salbris next year it will have been transformed into a beautiful 4x4!
March 4th, 2010, 7:04 pm |
ben
I would remove the battery, run the carb dry ,change the oil (used motor oil contains seal damaging acids or something) ,and maybe jack it up and support it up on wood blocks so the weight is off the tyres if its going to be static for a few years .
March 4th, 2010, 7:06 pm |
grifftravel
Old Bloke
and don't apply the handbrake
_________________ Now known as 602
http://www.2CVTech.co.uk
March 4th, 2010, 7:21 pm |
2CViking
Just park her as per normal but get someone to take her for a spind around the block every 3 month, no worries. We do this all the time with our cars down under + the many Europeans leaving car in Australia. Happy trip
March 4th, 2010, 7:32 pm |
Oboe, much the same advice as Ben has given, plus the following, since you're planning to be away for such a long spell... Remove the spark plugs, put a few shots of oil into each cylinder, turn the engine to top dead centre and screw the plugs in finger tight. On your retour, remove the plugs, disable the ignition and spin the engine over (with that new battery you've had to buy) until the oil warning light goes out. By that time, some of the fresh fuel that you've just put in the tank should have reached the carb, so you can install the plugs properly and fire her up. ken. ben wrote: I would remove the battery, run the carb dry ,change the oil (used motor oil contains seal damaging acids or something) ,and maybe jack it up and support it up on wood blocks so the weight is off the tyres if its going to be static for a few years .
March 4th, 2010, 9:34 pm |
oboe
Captain Slow
March 4th, 2010, 10:06 pm |
2CViking
ken wrote: Oboe, much the same advice as Ben has given, plus the following, since you're planning to be away for such a long spell... Remove the spark plugs, put a few shots of oil into each cylinder, turn the engine to top dead centre and screw the plugs in finger tight. On your retour, remove the plugs, disable the ignition and spin the engine over (with that new battery you've had to buy) until the oil warning light goes out. By that time, some of the fresh fuel that you've just put in the tank should have reached the carb, so you can install the plugs properly and fire her up. ken. ben wrote: I would remove the battery, run the carb dry ,change the oil (used motor oil contains seal damaging acids or something) ,and maybe jack it up and support it up on wood blocks so the weight is off the tyres if its going to be static for a few years . What happens if you don't. My Viking Van is sleeping in Melb. for the last year. When I picked him up, he started straight away, no worries.
March 4th, 2010, 10:13 pm |
Russell
Have you had it started regularly? I'd rather a bit of oil in the bores than risk it siezing, and to help it before the oil is circulating when restarted?
March 4th, 2010, 10:33 pm |
2CViking
Yes that's my whole point. Get someone to start and drive the beast around the block every 3 month and you don't need to do anything. I don't, never will.
March 4th, 2010, 10:48 pm |
Users browsing this forum: No registered users and 37 guests |
