View unanswered posts | View active topics It is currently November 19th, 2025, 3:33 pm
Reply to topic  [ 12 posts ]  Go to page Previous  1, 2
 Fuel Gauge
Post Re: Fuel Gauge
scoobastevesdad,
there isn't a carbon or hardened contact on the 'wiper' part of the rheostat.
Bending it only delays the day when the edge of the hole worn in the foot will catch one of the resistance wire windings and pull it all apart. :cry:
However, some careful work with a soldering iron will bridge that gap and give the sender a new lease of life...
scoobastevesdad wrote:
Whilst the earth may be one of the causes for a non working fuel gauge, the problem with them is that they work due to a variable resistor - as the float goes up or down it rubs a little brass strip up and down a wire wound plate. As the car ages, and with many miles under the clock, the actual brass contact, which I think when new has a carbon or hardened contact on it, actual wears out. A quick fix can be to bend the brass contact back towards the wire but this will only last a little while - if you have got the tank out to do this fix, then realistically the only real solution is to put a new sender in I'm afraid.
February 19th, 2010, 10:39 pm
lovin' the snatch
Post Re: Fuel Gauge
i started off writing down milage with lily, almost a year ago now, each time i'd put petrol in etc, see what milage i was getting from a couple of gallons etc, then i err forgot one day... then it was guesswork as to where i'd been, how many miles i'd done etc etc, not that i've ever ran out :) couple of days later we dropped the tank and sorted the sender, fuel gauge was good as gold ever since :)
something really odd that i now find hilarious, the wobbling from side to side when turning corners, i was in my dads car and kept looking at his fuel gauge waiting for it to move from one side to the other, then realised modern cars dont do that :/
|-|-' 602 For Life :)
Keep Them Looking Standard.
1979 Myosotis Blue Dyane6
1986 Sunrise Red 2cv6
February 20th, 2010, 5:30 am
Users browsing this forum: No registered users and 18 guests
