View unanswered posts | View active topics It is currently November 19th, 2025, 3:33 pm
 Fuel Gauge
Post Fuel Gauge
Does anyone actually have a fuel gauge that works?
Charlie is gone. Now 2CVless.
February 19th, 2010, 8:28 pm
Post Re: Fuel Gauge
Yes, actually... :lol:
February 19th, 2010, 8:31 pm
Post Re: Fuel Gauge
Altogether now... "Earth to sender!"
February 19th, 2010, 8:37 pm
Post Re: Fuel Gauge
yes !
Its not rocket science ;)
most problems occur with the earth, drop the tank and clean up the earth tag or put a ring terminal under one of the screws and earth it to the chassis side mount for the tank
in the mean time undo the connector on the LHS rear wing and earth it the guage on the dahs should read full
the voltage at the terminal should be about 8v-10v not 12.
sean
February 19th, 2010, 8:38 pm
Post Re: Fuel Gauge
oh oh pop quiz!
Star Man from "The Rise and Fall of Ziggy Stardust & the Spiders from Mars" 1972
no? :cry:
February 19th, 2010, 8:48 pm
Post Re: Fuel Gauge
Sean wrote:
no? :cry:
You just wanted an excuse to get the make-up out again, didn't you?
February 19th, 2010, 8:50 pm
Post Re: Fuel Gauge
Yes, but not originally :lol:
February 19th, 2010, 8:58 pm
Post Re: Fuel Gauge
Whilst the earth may be one of the causes for a non working fuel gauge, the problem with them is that they work due to a variable resistor - as the float goes up or down it rubs a little brass strip up and down a wire wound plate. As the car ages, and with many miles under the clock, the actual brass contact, which I think when new has a carbon or hardened contact on it, actual wears out. A quick fix can be to bend the brass contact back towards the wire but this will only last a little while - if you have got the tank out to do this fix, then realistically the only real solution is to put a new sender in I'm afraid.
February 19th, 2010, 9:12 pm
Post Re: Fuel Gauge
hummm, think I will stick to writing the milage down :)
February 19th, 2010, 9:31 pm
Post Re: Fuel Gauge
Alternatively it will finally kick into action after spending months or even years with the float in the downward (empty) position, as happened to me yesterday.
February 19th, 2010, 10:32 pm
Users browsing this forum: No registered users and 19 guests
