View unanswered posts | View active topics It is currently November 19th, 2025, 4:29 pm
Reply to topic  [ 112 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8 ... 12  Next
 2cv with smart turbo intercooler.
Post Re: 2cv with smart turbo intercooler.
Sounds and looks like a great car, well done!
one more thing, with the MP gass injection, are you running sequential injection? or still wasted spark with original ignition??
cheers
February 17th, 2010, 2:30 am
It's not running on sequential, because my flywheel has the 36-1 pattern into it so
the ecu doesn"t know if cil.1 has to ignite/inject or cil.2, im running wasted spark with the original black coil.
I just changed my megasquirt, when my engine starts to boost megasquirt will tableswitch.
I just did a quick test today; run without a good map but it boosted because the dumpvalve comes in when I release the throttle. (I hadn't a laptop connected)
Only 2 problems, the oilpipe to the left cilinder is leaking much oil, so I have to change the copper rings and the alternator has a shortcut so I have to fix that to.
Try to make a video and foto's in the weekend.
February 18th, 2010, 1:07 am
THIS IS IT!!!!!!
Work is (almost) done, today for the first time driving my
2CV Smart TURBO intercooler lpg/gpl!!
I still have a few things to do, making a windcatcher for the intercooler.
Iv'e made a watertank to cool the turbo down and to heat up the LPG. evaporator
The windscreenwasher container fits nice on top of the watertank.
A broken oilcooler gets a new live as a water-radiator, today the highest water temp. was under 30 degrees Celsius.
fully loaded
The exaust is made of 2cv pieces, first a heatexchange pipe of a 2cv witch fits perfectly to the turbo, then 2 pieces of the first silencer to end in the original pipe befor the second silencer.
By the way the engine is very quiet, maybe I remove the second silencer so I can here the turbo whisling.
A stabelizer is holding the front of the intercooler.
The air-inlet is from a moped from my son, it is to small but it was the only thing I could find.
February 20th, 2010, 8:40 pm
This is unbelievably impressive engineering. :D How did it drive?
February 20th, 2010, 9:33 pm
Well here is how it drove.......... (first time with turbo)
You know the car has a programmable ECU so I first have to learn the computer the new situation read Turbo.
When you drive of the car it is a little slower then a normal 2cv, but at about 2750rpm boost is comming in and yes you can really feel the car pulling away.
The only thing for now is that I could only do that with half the throttle but it is faster then a normal 2cv.
There where a few problems:
-Turbo boost didn't go higher then 0.5 bar
-Car didn't response on full throttle and boost.
- Car starts haevy knocking (igintion to early) under boost.
So when I came home I've changed the lenght of the waste gate
and i'm now busy to tune the maps ignition and injection.
Tomorrow a want to travel 500 km with the car
Here you can see a datalog from today's ride
As you can see the max boost was 0.5 bar (152 kpa)
Here you can see the turbo starts to boost at 2750 rpm MAP>100....
February 20th, 2010, 10:26 pm
It's a smooth rocket!!!!!!
Driving to my work today,
must make a video now its a cool car.........
boost 0.8 bar so far.............
February 23rd, 2010, 8:52 am
Here the first video for a quick impression how it idles, revs and accelerate...
http://www.youtube.com/watch?v=zfOfg7I_1VA
boost 0.8 bar
its running quit good when warm but cold it's a nightmare, I have to do some serious tuning.
I going to make a fixed camera-position and make some real video's soon.
March 1st, 2010, 11:54 pm
Just Awesome!
8-) 8-) 8-) 8-)
Played that video a few times with the volume turned way up!
March 3rd, 2010, 11:55 pm
THIS IS ONLY THE BEGINNING.... MUCH MORE TO COME, HAVE TO SORT OUT SOME MINOR PROBLEMS FIRST
March 3rd, 2010, 11:57 pm
The sound of a 2cv with smart turbo!!!!
http://www.youtube.com/user/www2cv4x4nl ... aTO2LkTkpM
March 21st, 2010, 11:12 pm
