View unanswered posts | View active topics It is currently April 30th, 2026, 12:13 pm
Reply to topic  [ 33 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Shock Absorbers
Post Re: Shock Absorbers
Yes I'm surprised Ken recommended that. After years with motorbikes with exposed damper rods, I always keep mine dry. As you say grease would attract dust and grit and make a perfect grinding paste. Not good for the seals.
February 9th, 2010, 12:39 pm
Guru's can be wrong too and it hurts :mrgreen:
February 9th, 2010, 1:02 pm
Jonathan wrote:
I have batteurs on the front of my F reg, makes a big difference to the feel of the car.....Highly recommended.
what are they?
February 9th, 2010, 2:29 pm
toomany2cvs wrote:
re usually long dead by this stage.
Unfortunately, the MOT here doesn't actually test for effectiveness, only for that drastic long-dead failure.
Isn't that the bounce test? on a 'normal' car it's quite easy to tell when the shocks are gone by pushing down the corner of the car. I thought that formed part of the test? Not that any tester would have a clue how much bounce an 2cv is meant to have
February 9th, 2010, 2:34 pm
what are they?
The big "bean cans" mounted on the front and rear arms of old 2cvs. They're "inertia dampers" - there's a big weight in them, damped by oil, and mounted on springs. As the wheel goes up rapidly, so the weight is forced against the lower spring. Then, at the top of the travel, the weight is forced against the upper spring.
Renault tried it in F1 a year or two ago, and promptly got slapped down...
February 9th, 2010, 2:35 pm
Yes, there's a bounce test...
http://www.motinfo.gov.uk/htdocs/m3s02000701.htm
...but they'll be useless on the road loooong before they fail that.
February 9th, 2010, 2:36 pm
the big cans here on the hub are batteurs Sam.
February 9th, 2010, 4:28 pm
If you fit batteurs expect arguments with mot testers when he does the bounce test.
February 9th, 2010, 5:05 pm
You betcha Russ,
even more fun, the 75 'shed' 2CV6 has batteurs front and dampers rear, that strange change over period.
Try explaining that!!!!!
February 9th, 2010, 5:12 pm
You betcha Russ,
Umm, batteurs were never fitted alone - if there's no hydraulic telescopics, there should be friction dampers.
February 9th, 2010, 5:31 pm
Users browsing this forum: No registered users and 82 guests
