View unanswered posts | View active topics It is currently November 19th, 2025, 3:33 pm
 Making a Manometer
Post Re: Making a Manometer
toomany2cvs wrote:
Willami wrote:
thing is you know what flat out is!! - i'm too much of a pussy to absolutely floor it for long periods, with what sounds like screaming to me - i could get more than 60 probably - i was being conservative..
Seriously, they like it. They thrive on it.
So long as the oil cooler is in sound condition and not sans fins. Then its
Thrash
heat
Thrash
more heat
Thrash
expand
Thrash
partial seizure
Thrash
busted rings
Thrash
broken piston
thrash
bang
death
1973 Ami 8 Club
January 25th, 2010, 5:20 pm
Willami wrote:
i was being conservative..W
Stay conservative and your engine will last forever. You need to understand metal, friction, lubrication and heat. Most don't which is fine but ignorance have killed many A model engines prematurely.
So please continue to drive like an old man. Don't forget to put a hat in the rear window. :mrgreen:
January 25th, 2010, 5:41 pm
+1 to Viking's advice ^ :)
I guess that, like me, he's had to put the pieces back together after someone's believed that the only way to drive an A series is with right foot buried in the bulkhead.
Some of the sweetest engines (and also gearboxes) I've known have belonged to drivers who don't thrash the machinery constantly.
Contrary to certain rumours, as and when asked to, those engines would usually outperform the ones that had been caned without mercy.
January 25th, 2010, 6:38 pm
Ah the "kill or cure" pilosophy
Usually the former, rarely the latter without some mechanical intervention. :lol:
January 25th, 2010, 7:48 pm
I think i'm going to take a bit easy and have the odd blast now and then
right back to the compression readings - so, choke off, throttle open :lol:
and i got 155psi on the OS & 180psi on the NS
so, better compression but i'm still concerned about the difference.
smells like oil seems to be burning for half a minute after a cold start, not after that though.....it's an old engine i guess...
cheers
Will
January 26th, 2010, 9:50 am
Have you done the tappets? they can affect the compression.
if you have it looks like its quite tired :(
still new rings and at worst barrels and pistons and should be a happy bunny
in the meantime beg steal or borrow an engine so you can get the cars one stripped for a look inside
January 26th, 2010, 11:09 am
cheers
Will
Cold start with blue smoke is common in older engines. Worn valve guides and valve stem seals allow small amounts of oil to enter the combustion chamber after turning the engine off. Starting cold, after a few minutes the oil is burned off and hopefully no more blue smoke. If it continue maybe piston rings are also worn allowing oil from the sump to blow past. The only way to fix it is to take heads and barrels off. No need to take the engine out. OK its an Ami but all guards off and voila easy access.
The compression test to me show too much variation but just on the limit. If the 155 psi drops below 145 psi soon, I would investigate. For the moment, I wouldn't worry too much.
January 26th, 2010, 11:48 am
Not sure I agree.
Some of these old M4 engines (if this is what is fitted) don't have valve stem seals (like other Citroens of the period eg DS) so will by their very design smoke a little bit on startup and on the over-run.
Anything over 125 Psi is fine. I've seen cars running with less than 100psi, not brilliantly mind but still running. If Willami is running the original engine these only have 7.75:1 compression anyway.
Is usual that the exhaust valves burn out on these M4 engines if you are using them everyday with the high octaine fuel available now, so keep an eye on the exhaust valve gap.
1973 Ami 8 Club
January 26th, 2010, 12:03 pm
Maybe right. I had the M28 9.0:1 in mind due to the 180 psi. Didn't think that M4 would reach 180 psi being an old engine.
January 26th, 2010, 12:16 pm
will's ami is M28, i think.
January 26th, 2010, 12:26 pm
Users browsing this forum: No registered users and 18 guests
