Has anyone replaced their kingpins with ball joints?
toomany2cvs
 Re: Has anyone replaced their kingpins with ball joints?
Devils Advocate wrote: Thanks to the simple fact that we are lousy at maintaining our cars, the yearly MOT will remain...  Thank gawd for small mercies.
| January 4th, 2010, 11:32 am |
bertiewhite
Joined: January 18th, 2009, 3:58 pm Posts: 682 Location: Lincolnshire
2CViking wrote: It is down to general knowledge of king pin design. At the risk of sounding dim, can anyone clarify the fundamental difference between a kingpin and a more modern design please? I understand that a kingpin is the bit that the hub assembly swivels on so (without crawling under my Fiesta) is it just that a "modern" hub is attached with 2 joints at the top and bottom instead of one pin through the centre?
| January 4th, 2010, 1:30 pm |
2CViking
bertiewhite wrote: 2CViking wrote: It is down to general knowledge of king pin design. At the risk of sounding dim, can anyone clarify the fundamental difference between a kingpin and a more modern design please? I understand that a kingpin is the bit that the hub assembly swivels on so (without crawling under my Fiesta) is it just that a "modern" hub is attached with 2 joints at the top and bottom instead of one pin through the centre?
| January 4th, 2010, 2:11 pm |
Pony
boys from the Barbour Works me n Bart are working on the problem
but easy to say hard to do
we have already spent 1 month at the drawing autocad table and solid works + hours checking and working out
so hopefully this year (with approval association from andrew gardner) we should be able to supply twin ball joint front arms with new hubs on an exchange bases with bolt in wheel bearings
And possibly sealed track rod ends!
however youll have to wait
i will post news when i got it end of summer is a possible start date
pony
| February 15th, 2010, 10:18 pm |
Users browsing this forum: No registered users and 18 guests |
