View unanswered posts | View active topics It is currently June 25th, 2025, 5:33 am
 Where do we go for Non-Related 2cv topics?
Post Where do we go for Non-Related 2cv topics?
I am sure somewhere amongst our fellow 2cv'ers someone will know the answer to this!
How do I play something I downloaded from BBC i-player, from my macbook to the tv?
I have a HDMI thingy on my tv, does that help?
December 30th, 2009, 4:11 pm
Post Re: Where do we go for Non-Related 2cv topics?
Here's the place for non 2cv stuff:
viewtopic.php?f=4&t=275&start=240
I can't answer your question unfortunately, Simon - but i'm sure one of forums many mac users will be able to help you out though! ;)
December 30th, 2009, 4:25 pm
Im not 100% sure as you have too fancy'ier operating system for my liking :lol: . However. Does your laptop have a HDMI out slot on the side? if so go get a hdmi lead (about £10) and see what happens when you plug it into the tv. I assume it will be as easy as that and you will either get a single desktop on the tv screen. or a dual desktop on both.
If you have no HDMI slot i assume you will have a VGA slot so try the same thing with a VGA cable. If Apples are as "easy" to use as they should be, i dont see why it wont be as simple as plug and play.
Hope that helps a bit
December 30th, 2009, 4:28 pm
I use iplayer-dl ( http://po-ru.com/projects/iplayer-downloader/ ) to download stuff "properly" from iplayer - it's saved as an MP3 (radio) or MP4 (TV) file on your hard disk. You could then burn that onto a DVD and play it in most DVD players. Whenever, not just within a week.
December 30th, 2009, 7:16 pm
many thanks, downloaded i-player-dl and it works :mrgreen:
cheers
Simon
December 30th, 2009, 10:38 pm
I should add that you need to keep on top of updates - the BBC have changed the way in which iplayer works, subtly, quite a few times - and each time they do, the downloader is broken.
December 30th, 2009, 11:31 pm
:ugeek: Which macbook is it? Apple sell various mini dvi adapters that will enable you to connect your laptop to a projector/external display/tv via vga, dvi and probably hdmi. You're only sending the signal to the tv so although iplayer is riddled with drm (which is intended prevent people sharing the files) whatevers on your laptop screen should show on the tv.
I hadnt heard of this, thank you adrian ;)
December 31st, 2009, 2:14 am
Trouble Maker
I have a macbook and use a Mini DVI to HDMI - two cables to connect to TV.
Hope this helps
Rich
www.barbour4x4.com
December 31st, 2009, 2:46 pm
It's worth being specific - the MP3/4 files saved by iplayer-dl are DRM free...
December 31st, 2009, 2:48 pm
Really? :shock: I didn't know that :oops: That's very good :)
December 31st, 2009, 7:36 pm
