View unanswered posts | View active topics It is currently September 24th, 2025, 12:38 pm
Reply to topic  [ 57 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
 Performance Loss...
Post Re: Performance Loss...
Luke wrote:
It's great fun getting recovered to Jon's house isn't it? Everyone should try it! ;)
No, please god no!! :o :lol:
November 16th, 2009, 9:34 pm
Last time I went there I had a flat tyre.
November 16th, 2009, 10:01 pm
lovin' the snatch
LOL Luke!!! i was leaving Spanners'! in actual fact... Spanners was the one to say "get recovered back to mine" :) although i bet you were alot more fustrated than you made look, to find out that you'd scrapped the dinner out with mrs Spanners to find me with a coil connection hanging off that i hadnt noticed...
|-|-' 602 For Life :)
Keep Them Looking Standard.
1979 Myosotis Blue Dyane6
1986 Sunrise Red 2cv6
November 17th, 2009, 4:16 am
lovin' the snatch
Post Re: Performance BACK
PERFORMANCE BACK! turns out.... after all... it was the fuel pump... now i have some pics to upload later on... but when i removed the fuel pump on the D*lly.... nice and clean... big splodge of grease, as normal... when i removed the fuel pump off this engine.... it was like devastation... completely black and gunged up with oil and crap... i dont know what the actual term for the stuff is, but it was 'orrible and nasty and possibly the reason why the last one died? i've not seen this before and i'm sure it didnt look like that a few months ago when i originally put that pump on it....
pics to follow!
Bonnet is DOWN Spanners! :D
November 18th, 2009, 6:01 pm
lovin' the snatch
believe it or not.... after swapping the fuel pump over... she went from brilliant to crap again.... hesitation again...
fitted an inline filter today (pump to carb pipe) started the car.... filter filled up... wahey... tick's over fine, car ran alright (for abit) started hesitating after a few miles home... when parked up outside the house, kept her running, checked again... Filter almost empty.... pushing up bubbles, bubbles and more bubbles.... cant see a leak after the pump... so im assuming ive got a crack in the pipe somewhere before the pump to the tank... will replace all though!
November 20th, 2009, 7:25 pm
It must be the pipe connecting the fuel sender in the tank to the fuel piipe oboe had this problem on the way to cz
Low and Loud!
November 21st, 2009, 1:54 am
Disconnect the whole lot. Gravity feed the carbi from a 1 liter clear coke bottle from inside the car and road test. Easy option to eliminate pump and tank sender etc.
November 21st, 2009, 1:58 am
lovin' the snatch
ok :o now where to mount this bottle...
November 21st, 2009, 3:20 pm
pics to follow!
Doubt its the cause just a syptom.
and crap is a perfectly fine ajective, usually found inside worn engines with dirty oil.
November 21st, 2009, 4:37 pm
Any 1 liter container will do, should be see through. Use coathanger wire and hook it somewhere above the dashboard, maybe rear vision mirror or crossbar above your head. Also hook it on your side mirror.
Bring spare fuel :mrgreen:
November 22nd, 2009, 1:13 am
Users browsing this forum: No registered users and 303 guests
