View unanswered posts | View active topics It is currently November 19th, 2025, 6:11 pm
 Crank and horsepower????
Post Crank and horsepower????
Hi.
How many Hp. and Nm. can crank, connecting rods and bearings withstand?
Pistons, cylinders and cylinder heads
I am not afraid of.
With my project, I am and will test the engine pieces to the extreme.what will be the first to break????
Image 2cv special 0,6Tii
viewtopic.php?f=5&t=1610
September 28th, 2009, 9:17 pm
Post Re: Crank and horsepower????
the big end will go first :shock:
what are you up to anyway?? wots your project?
Low and Loud!
September 28th, 2009, 9:24 pm
http://www.snail.s4.bizhat.com/viewtopi ... orum=snail ;)
September 29th, 2009, 12:07 am
Lars,
I've never seen a broken 2CV con rod yet and from what I've heard, isn't it usually the crankshaft itself which will let go at sustained high rpm ?
This was quite a good effort, however its damage started at the top and spread downwards rapidly once the top of the piston came adrift.
The trigger was an inlet valve head becoming detached from its stem, so I understand... :(
September 29th, 2009, 12:12 am
You need to ask the racing folks.
I've seen crank shaft split in two on a street car.
This one was never looked after. When I opened the engine, the oil was like rubber and lost its lubrications ability. Overheating killed this timing gear and the rest of the engine
September 29th, 2009, 9:00 am
And have a bit more power now.
September 29th, 2009, 1:22 pm
ken wrote:
Lars,
Harper did one at Mondello he wears the little end round his neck as a "talisman" at 24hrs
Lars my money is on little end bush giving up
or running big ends at those revs!
5 piece cranks more fragile
next is gudgeon pin seen one shattered like glass but "ahem" may have been less than standard....saying nothing.
September 29th, 2009, 9:40 pm
old oil and overheating is not something I think is a problem, oil is changed for every 4000km, or before a race. gear oil does not get much more than 5000km old.
The engine has an extra 13 rows oil cooler
September 30th, 2009, 8:46 pm
But how much power can it withstand?
October 8th, 2009, 2:38 pm
Sort of on Topic....
Before the days of turbos, the rule of thumb was 1000cc could deliver 100bhp.
So the potential is 60.2 bhp ;).
Just started the "rattle of death" from my offroad car @ 29bhp
October 8th, 2009, 6:00 pm
