View unanswered posts | View active topics It is currently August 14th, 2025, 11:24 am
Reply to topic  [ 206 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 21  Next
 Wegenwacht AKS 400.
Post Re: AKS 400.
You reckon? I would love to, but how much to they cost? One question though, arn't springs different sizes on vans compared to cars?
February 10th, 2009, 7:07 pm
gym bunny
Post Re: AKS 400.
van springs different same as ami 8 and super are too...
1299cc FTW
February 10th, 2009, 7:20 pm
Post Re: AKS 400.
But what im wondering is can i get some uprated sprongs like russ has for the 2cv? Who will sell em?
February 10th, 2009, 7:29 pm
gym bunny
Post Re: AKS 400.
not sure on van diameter springs? plus the rates will be different. i would probably fit stiffer shocks for a start to help stop it bouncing and bashing the road so bad. my ami has some sort of home made ones on it where they were drilled, drained, welded and refilled with gearbox oil, you can change the oil depending on the viscosity you want and therefore the speed of movement and hardness.
springs are expensive and hard to change and annoying, especially on van or ami!
1299cc FTW
February 10th, 2009, 7:33 pm
Post Re: AKS 400.
You sure?
Might be same diameter but are the cans the same length?
February 10th, 2009, 8:46 pm
gym bunny
Post Re: AKS 400.
didnt mean it like that. I should have written van srpings different as are ami and super ones too!
are they connected or not connected or something too? to do with the rubber band around them?! who knows!?
1299cc FTW
February 10th, 2009, 9:35 pm
Post Re: AKS 400.
That rubber band, as far as I can see, does nothing, it doesnt appear to have a function on mine anyways. What i meant was the spring can mount is in a different place on an ami chassis to a 2cv saloon, because the can is a different length, but i don't know whether a van spring is the same length as a 2cv saloon or an ami, or whether it's different again..?
February 10th, 2009, 9:45 pm
Post Re: AKS 400.
I raised her up a bit. :oops:
From looking underneath its no way as bad as it sounds, Seems a lot of the impact was on the chassis, but its started scraping on the crossbox too.
Can you see what i mean about the chassis having a slight kink?
February 12th, 2009, 12:01 am
Post Re: AKS 400.
Did this last year in november leaving the ferry, Luckily i was the last one geting off. I had to give it some to get off. :lol:
February 12th, 2009, 12:27 am
Post Re: AKS 400.
I remember seeing this van buried in a garage before you got it.
You've done a grand job getting it going again.
Regarding springs we have played a lot with them for the 4x4s. Van, Ami and that have thicker wire and bigger diameter. They also don't have the rubbers on the ed of the cans. We can get special ones made to order.
Best to call Louis or PM me if you need more info on them...
February 19th, 2009, 2:35 pm
Users browsing this forum: No registered users and 19 guests
