View unanswered posts | View active topics It is currently June 19th, 2026, 6:56 pm
Reply to topic  [ 8 posts ]
 Just a quick one...
Post Just a quick one...
Morning.
I know there's tumbleweed blowing round these parts this weekend cos everybody is away getting arseholed in a field near Cambridge, but some of us have to work you know. :mrgreen:
Luckily enough though we have a plasterer coming to do the spare room on Monday so, instead of being forced to go out for the day and enjoy myself sitting in nose-tail bank holiday gridlock, I have the pleasure of a day in the garage putting Mad Cyrils back brakes back together.
To do this properly I'm intending to liberate a large torque wrench from work to do the 44mm hub nut up to the correct tightness.
So my question is this:
What is the correct torque for the rear hub nut?
Thanks for listening. :D
August 29th, 2009, 12:30 pm
Post Re: Just a quick one...
The Haynes book-of-Bollocks states it should be 290 lb/f
August 29th, 2009, 12:46 pm
Super Smashing Great.
I'll be nicking the biggest torque wrench on a short term basis then.
Ta, very much Russ. 8-)
August 29th, 2009, 1:16 pm
Old Bloke
So it has some uses then.
I have a one metre long 3/4 drive breaker bar and when tightening said nut apply a reasonable but not enthusiastic pressure on tightening. I alway [and I mean always] fit a new nut. Never had one come off yet.
Now known as 602
http://www.2CVTech.co.uk
August 29th, 2009, 1:22 pm
The reason for 30-35 kg is not to prevent it coming off. Its to get the correct preload on the inner bearings. The outside ring nut front and rear is also 30-35 kg preload on the outside bearing. Same for the drive shaft nuts.
August 29th, 2009, 2:03 pm
Lenny
Citroens own manual states 252-288ftlb 35-40Nm
which is pretty much FT with a long breaker ;)
August 30th, 2009, 7:44 pm
Old Bloke
Just tried it out on a car I was working on. Using my trusty 1 metre breaker bar and a Facom socket, I tightened it sensibly. I then checked with my torque wrench and it was 260 ft/lbs [its an old torque wrench and not yet metricated]
Now known as 602
August 31st, 2009, 7:26 pm
I borrowed a monster torque wrench and did them up to 290lbft. Been for a quick spin and everything seems dandy.
Ta very much all.
August 31st, 2009, 9:47 pm
Users browsing this forum: No registered users and 184 guests
