AZL57
Joined: October 22nd, 2014, 10:59 pm Posts: 2278 Location: South-Limburg
 Re: Transfer box.. A new version...
could also cut an piece out of the chassis...
| July 30th, 2024, 3:25 pm |
subarupete
Joined: March 5th, 2009, 6:23 pm Posts: 2251 Location: Near Monmouth
Looked are various options, but the transfer box is too deep.
Need to reduce the height so it doesnt protude below the bottom the the chassis!
As they say measure twice.....
| July 30th, 2024, 8:53 pm |
Roger V
Joined: March 21st, 2013, 12:04 am Posts: 1661 Location: Exeter, Devon
Wind up the suspension!
| July 31st, 2024, 10:17 pm |
subarupete
Then I could use it for-------- Crop Spraying:)
| August 1st, 2024, 5:15 pm |
subarupete
Back plate Number 2....Its a prototype/WIP/Bodge... Attachment:
| August 10th, 2024, 6:00 pm |
subarupete
All the new parts made "in house" or modified Citroen parts. Only the Tig welding and wire-cutting and bolts and bearings from suppliers/experts. Waiting on the small (13 tooth) sprocket to be edm/wire-cut for the splines. Now to carefully clean and assemble into a working transfer box. The housing now in many parts, due to "bodgeing" but ended up with Triplex chain and the box now fits with +/- 20mm adjustment/clearance. Just need a Mehari 4x4 style of chassis:) Attachment:
| August 12th, 2024, 1:39 pm |
Roger V
Cool
| August 12th, 2024, 1:44 pm |
subarupete
Not up here very humid:)
| August 12th, 2024, 1:48 pm |
Roger V
Ok... humid then ...
| August 12th, 2024, 1:54 pm |
subarupete
Getting spilnes cut, is now much harder:(
So a compromise....the drive flange (EN24T steel) welded to a turned down unused sprocket (EN8? steel).
Will they weld and will they survive?
| August 20th, 2024, 1:51 pm |
