View unanswered posts | View active topics It is currently June 19th, 2026, 12:33 pm
Reply to topic  [ 129 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9 ... 13  Next
Nice job, we had an CNC at work. You could make a program and the machine did the work.
May 6th, 2024, 10:12 am
CNC would be nice, Lottery win maybe:)
Bit of welding , Part number stamped:) and a breather fitted.
May 8th, 2024, 3:06 pm
Loverly and warm in the shed, so I turned up a bung to go the the clutch shaft hole.
May 9th, 2024, 11:50 am
looks nice, as you have part numbers people can order them ;-)
May 9th, 2024, 12:06 pm
:lol:
May 9th, 2024, 12:59 pm
Was all going quite well, making the oil seal/bearing plate.
See photo, the rebate on the back, about 2mm of centre:(.
Hopefully, I can get a larger OD seal and of set the hole to match the "Bodged" bit.
May 10th, 2024, 2:49 pm
Oh, that mistake is too easy to do. Have learned again about milling, with my tiny Bernardo...
Working area about 100mm x 300mm, ideal to make small parts ro RC cars and Helicopters. Maybe enough to make some 4x4 parts also...
May 10th, 2024, 4:25 pm
I have an Emco Unimat 3 for all kind of tinkering also clocks etc.
May 10th, 2024, 4:34 pm
Hi, Guys,
Small is good, teaches you Patience:)
May 10th, 2024, 5:42 pm
To cheer myself up, I put the diff together and did a quick video.
Weight is currently and 25Kg, when finished 26Kg with all bolts and support brackets etc.
https://www.youtube.com/shorts/sBXIjgUM3Hw
May 10th, 2024, 5:45 pm
