View unanswered posts | View active topics It is currently June 19th, 2026, 2:01 am
Reply to topic  [ 123 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10, 11, 12, 13  Next
 2CV engine with Visa Barrels, heads etc
Post Re: 2CV engine with Visa Barrels, heads etc
A 3k watt kettle I might add :D
The duel fuel carb arrived. in the box was a a sponge air filter. So I thought I may try printing a box for it. :)
On a completely different note, I appear to have stumbled across a fibreglass bonnet for the Shedouin! It's on it's way .... :D :D :D
November 9th, 2023, 1:36 pm
How on earth did you find that?
November 9th, 2023, 11:17 pm
@Ianredspecial
A Bedouin came up for sale on FB. It was a bit of a dog, but cheap. I did say if he ended up scrapping, I would be interested in the Bonnet. As it turned out, he appreared to have a spare bonnet. !!! :D
November 10th, 2023, 3:19 pm
The starter kit has arrived. I need to get the fylwheel nut un done, and the crank is turning!
November 10th, 2023, 3:21 pm
Ok, got over that hurdle :) my mate Jenks turned up with one of those torque thingy's. Took about 5 seconds. A screw driver wedged behind the flywheel, and a smack on the crank with a copper malllet, and the fly wheel came off.
And then it rained. :D :lol:
So I shall do some more air filter box design :)
November 10th, 2023, 5:14 pm
The Bonnet arrived :) It looks ok :D
Took it over to the garage the Shed is in. Tried to start the Shed, but it wasn't having any of it :lol: Took the battery out and brought back to put on charge. Also took the leisure battery out of the van for a charge up. I'm considering using the leisure battery for the Gen and lighting in the garage.
November 11th, 2023, 5:39 pm
Otherwise you can put a belt on de the generator and hook it up to the 2cv engine...
November 12th, 2023, 12:18 am
@azl57 It did occur to me :lol: :D
November 12th, 2023, 8:36 am
So, a bit of progress on the Gen front ...
Starter motor installed (doesn't quite fit by 1mm, but filed out). :) It now cranks :D
All the wiring is pulled out to rewire! Thats progress right! :lol:
November 12th, 2023, 8:08 pm
nice.... all that you pull out can't cause a problem.. ;-)
November 12th, 2023, 11:00 pm
Users browsing this forum: Google [Bot] and 230 guests
