View unanswered posts | View active topics It is currently June 19th, 2026, 6:09 am
Reply to topic  [ 73 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8  Next
 EPB Refurb
Post Re: EPB Refurb
You can put the heads in the dishwasher.... ;-)
December 4th, 2022, 11:14 pm
Post Re: EPB Refurb
An old one maybe, does it remove the “baked on” stuff.
December 5th, 2022, 10:45 am
Post Re: EPB Refurb
Dish washers do not remove as much as you would think. I must be using the wrong tablets :lol:
December 5th, 2022, 11:58 am
Post Re: EPB Refurb
Maybe spray it with oven cleaner first??? A friend did use the dishwasher too and then took the whole engine in the bath tub for cleaning and than his parents came home from holliday.... ;-)
December 5th, 2022, 9:38 pm
Post Re: EPB Refurb
The steering Rack Saga.
Rebuilt Steering Rack with added grease nipples, fitted to the chassis all OK.
Came to fit the body and found the hole for the steering pinion, incorrect, hole altered accordingly.
Fitted the steering column and found the its alignment was not correct, even with a spacer under the speedo housing.
Solution… rummage in the shed, found a GS column, with UJ’s. Cut, weld and refit, The bolt is in the post.
I think the rack was from a AMI, ideas welcome.
See photos
October 9th, 2023, 10:00 am
Post Re: EPB Refurb
Post Re: EPB Refurb
nice saga....i think meharis had uj in the column too.
October 9th, 2023, 5:29 pm
Post Re: EPB Refurb
Yes, Mehari, Ami8 and AmiSuper had UJ and Ami has different angle of the steering worm gear. Not sure about Mehari about the angle...
Another funny detail, RHD axle tube is made from LHD tube, cutting, re-arrange and welding back together. LHD tube is one solid piece...
October 9th, 2023, 5:41 pm
Post Re: EPB Refurb
The meharis body is rather flexible i think they put in an UJ as a precaution.
October 10th, 2023, 2:37 pm
Post Re: EPB Refurb
:D
October 10th, 2023, 6:01 pm
Users browsing this forum: No registered users and 67 guests
