View unanswered posts | View active topics It is currently June 19th, 2026, 6:40 am
Reply to topic  [ 123 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 13  Next
 2CV engine with Visa Barrels, heads etc
Post Re: 2CV engine with Visa Barrels, heads etc
I'm looking to build an Engine Test Rig
Tool Chest/Trolley will park underneath :)
September 9th, 2023, 10:51 pm
Angle iron for the main part of the rig is ordered. :) The idea is it will be on castors.
I bought the tool trolley, and it arrived damaged, Had choice to return, but I negotiated a partial refund. A block of wood, and a few smacks with a hammer and it's fine now. :)
No further progress on the engine as life got in the way :D It's just a case of further cleaning, sort out some gaskets, and reasemble.
Unfortunately, some more life is about to get in the way, but watch this space :D
Edit
Oh!, and I've ordered a surge tank from China, with a view to 2CVi.
September 11th, 2023, 1:00 pm
I have a bell housing bolted on a frame. There you can hang the engine on and a starter motor.
September 11th, 2023, 9:55 pm
Yes, good point, and I did think of that. But thought this may give a longer/wider wheelbase. Probably over thinking it a bit :D
September 11th, 2023, 10:24 pm
I like your ideas, please keep posting :D
September 11th, 2023, 10:44 pm
Friend of mine makes these engine yokes for VW/Porsche engines......Slots into a standard Machine Mart stand. Allows the engine to be rotated and the casing split !
He also does a version with a starter motor mount.....
September 12th, 2023, 10:03 am
How clever is that.
OK, so thats some bits of iron stuck together :D
there are plates on the bottom for some castors :)
September 24th, 2023, 8:41 pm
Some progress :)
September 25th, 2023, 3:02 pm
Some diagonal braces would be safe i think.
The 2cv engine is normally build on it's side, bolted on to an holder. The did the same in the factory.
September 25th, 2023, 5:00 pm
Users browsing this forum: No registered users and 198 guests
