Jonathan
 Re: My 2cv
AZL57 wrote: Is the black not from a backfire? It has backfired once or twice. It has also blown the top off the air filter housing which was already secured with two self-tapping screws. It's now fitted with three self-tapping screws!!
| December 28th, 2022, 3:09 pm |
Jonathan
 Re: My 2cv
Ianredspecial wrote: By the way pictures have to be shrunk! It works fine but until I realised that it was very frustrating. Test photo Edit:- That worked
| December 28th, 2022, 5:15 pm |
AZL57
 Re: My 2cv
FUK....????
| December 28th, 2022, 6:42 pm |
Roger V
 Re: My 2cv
+1 to FUK Lol
If you have had back fires, and you have one clean plug, and one sooty plug (or is it oily), then it suggests you have false air on the clean plug side. Try putting an 11mm ring spanner on the bolts holding the spider to the head on the inlet manifold. Don't be excessive, but can you easily tighten the bolts.
Often, carb cleaner is very flamable. When you have cleaned the carb, and re assembled, with the engine warmed up, if you spray a little cleaner around the inlet manifold to head joints, and the base of the carb, do the revs rise?
| December 28th, 2022, 7:11 pm |
Jonathan
 Re: My 2cv
Thanks for that Roger, if I get any more issues I'll take to looking at those areas. After soaking the carb yesterday I tried the car this morning and it fired into life IMMEDIATELY. It hasn't behaved like that since before the recent cold and damp weather arrived. It took me by real surprise as I was expecting it to struggle yet again. I'm feeling quite chuffed at the moment  Fingers crossed that I've finally managed to cure the problem. Thanks for all the help and pointers chaps. Watch this Space
| December 29th, 2022, 2:29 pm |
Roger V
 Re: My 2cv
Thats cool  Though it could be you have primed it with something volatile  Does indicate its a fuel/air issue though.  When warmed up, does it idle ok?
| December 29th, 2022, 5:05 pm |
Jonathan
 Re: My 2cv
Yep, the idle is good.
| December 29th, 2022, 7:03 pm |
Jonathan
 Re: My 2cv
I'd written a lengthy piece about the Morris, and the 2CV, on the Pre-War Minor forum, but a copy and paste won't post to this forum, very annoying.
| December 29th, 2022, 7:05 pm |
Jonathan
 Re: My 2cv
I took the 2CV out again this afternoon and it fired up straight away again. So I'm hopeful.
| December 29th, 2022, 7:06 pm |
AZL57
 Re: My 2cv
Try to copy to a mail or a word-file and then copy to here, might work??
| December 29th, 2022, 11:01 pm |
Users browsing this forum: No registered users and 357 guests |
