Page 1 of 1
[ 3 posts ] |
Ianredspecial
Joined: June 22nd, 2014, 8:09 pm Posts: 1326 Location: Reading, Berks UK
 Fuel Tank Slight Vacuum
This was odd, not something I've ever had on my Deuche. I went to refuel and there was a slight vacuum when I removed the cap.
How strange is that. I did have to bump up the idle the other day while on a trip as it seemed to undulate a bit and stalled. Drove 100 miles home at 60mph no problems at all, but a couple days later (today) it did falter a bit so I had to pull over on the way to the petrol station. Idled a minute and it was fine again.
| October 26th, 2022, 9:33 pm |
Roger V
 Re: Fuel Tank Slight Vacuum
May not be related. Caps are designed to let air into the tank when there is a vacuume from using fuel. Try some WD40 on the cap.
| October 27th, 2022, 1:24 am |
Ianredspecial
The fuel cap had been a bit stiff with the key for the last year or two and I finally got around to putting a bit of oil in the key slot a couple weeks ago which improved it hugely. Hmm I wonder if I've gummed up the vent. I shall investigate!
| October 27th, 2022, 11:33 am |
Page 1 of 1
[ 3 posts ] |
Users browsing this forum: Google [Bot] and 230 guests |
