subarupete
Joined: March 5th, 2009, 6:23 pm Posts: 2257 Location: Near Monmouth
 Re: EPB Refurb
Thanks for the info, Bushes on their way now, but will rummage through to plumbing box, for the next set of spindles. However the bronze are oil sintered so will outlast me. Cheers Peter
| July 10th, 2022, 11:17 am |
jasu
Joined: August 8th, 2012, 11:00 am Posts: 510 Location: Korpilahti, Finland
 Re: EPB Refurb
Older spindles are much better than later, and easier to service. And on some late spindle, there isn't any bronze bushing, only drilled hole for shaft...
Those linkages are near overkill, but on good way.like them...
| July 10th, 2022, 3:05 pm |
subarupete
 Re: EPB Refurb
Could have used M4 rose joints, but they are more expensive, they are used on RC planes etc..
| July 10th, 2022, 4:37 pm |
subarupete
 Re: EPB Refurb
Update .. but still lots to do... LED rear lights. Attachment:
Parts on ebay, but cheaper if you use Aliexpress and wait... https://www.ebay.co.uk/itm/255496392311 ... 0667.m2042Found the boot stay.. Attachment:
Change over fuel tap (under rear seat) for additional fuel tank. Attachment:
Craftmaster Under Coat on rear wing (with runs). Attachment:
Essential extra Badge. Attachment:
Carpet Lining on rear wing. Attachment:
| July 30th, 2022, 9:28 am |
Roger V
 Re: EPB Refurb
That's coming along nicely Pete.  I like the idea of the light conversion.  Can you still see the lights from anywhere that is not directly behind?
| July 30th, 2022, 10:22 am |
subarupete
 Re: EPB Refurb
Bulbs being a point source are the best option. the LED replacments are expensive. The LED arrays are brigher and the Fresel Lens cover does its job. See photo Attachment:
Cheers ps They work under water!
| July 30th, 2022, 2:17 pm |
subarupete
 Re: EPB Refurb
Can somebody post some pictures of the Rear Door….rubber door seal/metal strip, rivets, nylon and plastic. Have the parts but what goes on the door and what goes on the pillar??? Thanks in advance..
| August 1st, 2022, 12:20 pm |
subarupete
 Re: EPB Refurb
Engine and Gearbox ready to refit. Attachment:
| August 5th, 2022, 9:12 pm |
Roger V
 Re: EPB Refurb
Cool  Though have to say I really liked the purple... then realised it was the lifting harness!!
| August 5th, 2022, 9:47 pm |
subarupete
 Re: EPB Refurb
| August 7th, 2022, 3:23 pm |
Users browsing this forum: No registered users and 68 guests |
