View unanswered posts | View active topics It is currently May 8th, 2026, 12:15 am
Reply to topic  [ 993 posts ]  Go to page Previous  1 ... 57, 58, 59, 60, 61, 62, 63 ... 100  Next
 AZL 1957
Post Re: AZL 1957
Well is was only for one day. It was grey and very cold today. Since yesterday the 57 started smoking a lot in idle. I think the valve guides have had it.
January 25th, 2022, 10:59 pm
Post Re: AZL 1957
Very strange the smoking was almost over. And yes i did check the oil level and that was still ok.. ;-)
January 26th, 2022, 10:44 pm
Post Re: AZL 1957
what colour smoke?
January 26th, 2022, 11:29 pm
Post Re: AZL 1957
grey blueish.
January 27th, 2022, 9:44 am
Post Re: AZL 1957
Appears to be oil then :)
I would be checking the breather first though, if it appears variable.
It's not impossible that oil quality can make a difference.
January 27th, 2022, 2:16 pm
Post Re: AZL 1957
Well, i did check the breather out last night and was completly "drowned" in oil. So i cleaned it up and put a new one in. No help it still smokes but not so much. But i think it might be the oil as i had to put a bit thinnner oil in. We will see how it advances. Had some engine cut outs on the way to work today. Gave the idle jet a clean and it was running ok on the way back.
January 28th, 2022, 6:39 pm
Post Re: AZL 1957
Still my favourite car on the forum. It's so cool.
January 28th, 2022, 10:30 pm
Post Re: AZL 1957
Have cleaned sparkplugs and contacts, they needed a small correction in the timing too. Starts perfectly again. There is a small oil leak near the oil cooler somewhere. The left side of the engine was rather greasy. There was even some oil in the claxon..
January 29th, 2022, 4:52 pm
Post Re: AZL 1957
take a look where the cooler oil pipes connect to the engine.
the differing metals of the tube and the threaded metal bit, cause galvanic erosion. This causes the aluminium tube/s to erode and weaken and eventually to have holes in it.
don't ask me how I know :)
January 29th, 2022, 5:18 pm
Post Re: AZL 1957
The aluminium ones also suffer from the salt spray in the winter. On my blue deuche the aluminium was worn so thin like tin foil. When it put the pressurewasher on it the lamelles crumbled. But the coolers in the old cars are made of brass and copper.
January 29th, 2022, 7:15 pm
Users browsing this forum: No registered users and 243 guests
