View unanswered posts | View active topics It is currently November 19th, 2025, 11:58 am
Reply to topic  [ 7 posts ]
 Anti Roll Bar -Sway Bar (ARB)
Post Anti Roll Bar -Sway Bar (ARB)
I'm looking to fit an ARB I bought, to the Shed
Any Tips :)
January 23rd, 2022, 11:42 pm
Post Re: Anti Roll Bar -Sway Bar (ARB)
That from an ami8?
February 3rd, 2022, 7:08 pm
I believe it is. :)
I have the bar and clips from one source (Pete Sparrow), but it did not have the endplates. From Simon Sobey, I have obtained one end plate with the spacer already welded on and threaded. He also supplied a 'blank' endplate for the other end. :)
So far, I have cut, drilled and tapped some 10mm steel for the blank plate.
In the next few days I hope to visit my friend up the road to weld it up as he has professional welding equipment, and would like a laugh at my attempts. :lol:
Yesterday, new shock absorbers arrived from Ecas, So I thought it best to fit it all together as the exhaust probably needs to be moved out of the way.
I have looked at it a few times wondering how to get the bar in place, and think perhaps I need to support the gearbox and remove the rear gearbox mount.
Any thoughts are welcome :D
February 3rd, 2022, 8:34 pm
welding is done :D
February 8th, 2022, 10:32 pm
Roger V wrote:
.....obtained one end plate ....... also a 'blank' endplate .....new shock absorbers .....
I assume you checked that the end-plates both have the same size mounting studs for the shock absorbers: (12mm on 2cv, AZU, Dyane, Mehari. 14mm on Ami, AK, Acadiane).
February 10th, 2022, 1:48 am
I did thanks. Didn't occur to me, But Simon checked :)
February 15th, 2022, 9:57 pm
The benefit of buying parts from someone who knows his stuff. ;)
February 16th, 2022, 11:30 am
