Author |
Roger V
Joined: March 21st, 2013, 12:04 am Posts: 1633 Location: Exeter, Devon
 Re: Yellow Dyane
Rob  Something I was introduced to by a friendly MOT man, was Seam Sealer. Not cheap, but more flexible than filler. Check if it's cellulose based and what is under/over. This does need to be applied externally, as opposed to beer, which can be enjoyed internally.  Enjoy .... I'll just put up with my cider then, shall I ...
May 16th, 2021, 6:57 pm |
rob massey55
Joined: December 21st, 2014, 7:33 pm Posts: 877 Location: Rhayader Mid Wales
 Re: Yellow Dyane
Thanks Rog., I've used it on the van and the 2cv before and it's very good. I've used 3M stuff before but I may try something different this time. Oh i've got cider as well...as well as Gin etc.  .
May 16th, 2021, 7:19 pm |
rob massey55
 Re: Yellow Dyane
It's a public holiday over here so what better way to spend it . P1030351 by Robndaisy, on Flickr Lefthand rear, oh dear, P1030352 by Robndaisy, on Flickr ok, P1030355 by Robndaisy, on Flickr Someone's repaired it, P1030357 by Robndaisy, on Flickr Wow! gas welding, that's rare these days but back then... P1030358 by Robndaisy, on Flickr spotweld 4 layers together and mature since 1980. Considering that the 4 pieces add up to about 3.5 mm. when new, it's expansion over time has been quite dramatic  . P1030361 by Robndaisy, on Flickr Ordered repair C posts and began prepping up for the sill repair. P1030348 by Robndaisy, on Flickr I left the windscreen repair like this for now, fun with bodyfiller later...much later  . P1030356 by Robndaisy, on Flickr If I sit there long enough, drinking tea, it may repair itself.
May 31st, 2021, 6:42 pm |
AZL57
Joined: October 22nd, 2014, 10:59 pm Posts: 2215 Location: South-Limburg
 Re: Yellow Dyane
 You hoovered away the bad parts of the body?
May 31st, 2021, 9:38 pm |
Geert
Joined: July 10th, 2010, 12:35 pm Posts: 1169 Location: Magyarország
 Re: Yellow Dyane
Right. Time for a cuppa .
June 1st, 2021, 7:28 am |
Roger V
 Re: Yellow Dyane
I find if I sit still to long drinking tea, the rust gains on me ..
June 1st, 2021, 1:09 pm |
rob massey55
 Re: Yellow Dyane
The thing is lads, it's not as bad as that van was, is it?  if I can just keep chipping away, I'll soon be down to Ken's chassis  .
June 1st, 2021, 6:54 pm |
AZL57
 Re: Yellow Dyane
Then get a mehari body to bolt on...
June 1st, 2021, 8:27 pm |
rob massey55
 Re: Yellow Dyane
P1030362 by Robndaisy, on Flickr I've got to get this and the others off, 26mm. hex, easy or not?
June 6th, 2021, 10:00 pm |
subarupete
Joined: March 5th, 2009, 6:23 pm Posts: 2247 Location: Near Monmouth
 Re: Yellow Dyane
Easy ....if natures loctite (rust) hasn't taken hold.
June 7th, 2021, 8:44 am |
Users browsing this forum: No registered users and 27 guests |
