View unanswered posts | View active topics It is currently May 7th, 2026, 10:31 am
 Rust Rot Excessive
Post Rust Rot Excessive
Got myself a refurb body shell as the current item is very tired.
Now to cut a big hole in the lower bulkhead for the prop shaft :)
Old Body Shell....
Low bulkhead and boot and the following.
May 26th, 2021, 2:01 pm
Post Re: Rust Rot Excessive
Markout the GOOD metal to be removed...:)
May 29th, 2021, 2:25 pm
Added some good Zintec to the hole with some average welds
May 30th, 2021, 12:03 pm
all good stuff Pete, Ive been excavating some of the rusty stuff as well. :)
May 31st, 2021, 6:26 pm
Yet another large hole, this time in the boot.
June 4th, 2021, 10:11 am
The holes have an advantage, they won't rust... ;-)
June 4th, 2021, 4:25 pm
:lol: also less kg that is until it, gets filled in with more metal than was removed :(
June 4th, 2021, 4:43 pm
I can see that you've been paying attention :) .
June 6th, 2021, 10:06 pm
You have to let the rain water out some how!
June 7th, 2021, 6:10 pm
Covered with Primer and Seam Sealer looks reasonable :)
Added a kg or Two as the metal is 1.5mm where as the original is 1.2mm or less.
June 9th, 2021, 4:48 pm
Users browsing this forum: No registered users and 349 guests
