We have liftoff.....AZU 250 rebuild thread
Geert
Joined: July 10th, 2010, 12:35 pm Posts: 1205 Location: Magyarország
 Re: We have liftoff.....AZU 250 rebuild thread
"szép " as they say here.
| February 24th, 2021, 6:58 pm |
48pop
Joined: May 23rd, 2011, 7:14 pm Posts: 309 Location: ecosse
Been a while ! So.....Noticed a wee spot of oil when parked up, on a normally "dryish" engine. With visions of crankshaft oil seals, oil cooler unions etc. I removed the fan and rubber shield.....odd, all looks fine and dry. A brief wipe around with a cloth and degreaser and I put it all back together....As my nose was level with the coil I spotted the source of the oil spotting.....the COIL, dripping from the middle joint. Not seen that before...Replaced with a spare and all is well. Also managed to get my "clacker" indicator switch back in, no more misindications........ Also spotted the holed crossbox....
| April 17th, 2021, 11:19 pm |
48pop
If anyone is looking at this thread, you will know that the van has a nice, shiny Chassis on it now. I held on to the old one with the intention of fixing it up and storing .......(goodness knows why....) Top and bottom plates perforated and some of the stiffeners on top and bottom flanges. Anyway, took the grinder to it yesterday, its not too bad    photo hostNice and clean...ish at the back  Some weldy, weldy to happen, then clean, paint, wax
| June 19th, 2021, 12:39 pm |
subarupete
Joined: March 5th, 2009, 6:23 pm Posts: 2257 Location: Near Monmouth
Repair, refurbish, reuse, gets my vote
| June 19th, 2021, 5:46 pm |
48pop
So today.... One of the outriggers looked like this  Chopped it back and made a wee replacement  One of the outriggers was totally missing  So after some cutting and hammering I had this....  Then rain stopped play for the day......Welding next wk probably
| June 20th, 2021, 7:03 pm |
AZL57
Nice job, i seen worse exemples saved.
| June 20th, 2021, 10:12 pm |
48pop
welding day...... Wainting on some fluids before putting base and floor plates.....
| June 27th, 2021, 12:13 am |
Geert
Good job !
| June 27th, 2021, 7:14 am |
AZL57
A friend did waxoil his chassis and the started to weld..... boom a plier that was laying on the chassis was stuck in the ceiling....
| June 27th, 2021, 1:16 pm |
subarupete
Was grinding with a battery “on charge” at the other end of the bench... bang....battery with the top off .....acid on the bench, now very careful when welding, grinding etc...
| June 27th, 2021, 1:23 pm |
Users browsing this forum: No registered users and 215 guests |
