Crankcase breather/Reniflard is it duff?
Author |
Greysnail13
 Re: Crankcase breather/Reniflard is it duff?
Thanks Eirik, a good endorsement from you. Whilst we are in ‘lockdown’ it’s a good time to get some goodies especially if it helps maintaining the 2cv. I had a 20 mile run in the car yesterday, troublefree & it ran, I’m slightly hesitant to say this but, very well. It seemed smoother & quieter with the repaired breather, but maybe just my imagination. I have to say I am more hopeful than before, time will tell.
January 19th, 2021, 1:59 pm |
Roger V
Joined: March 21st, 2013, 12:04 am Posts: 1632 Location: Exeter, Devon
may be a good time to check your air filter
January 20th, 2021, 8:10 pm |
Roger V
@subarupete
Looking back at your images, I note you appear to have added an additional round plate to attach the reeds to. Was there a reason for not fitting them to the original part?
April 7th, 2021, 12:32 pm |
subarupete
Joined: March 5th, 2009, 6:23 pm Posts: 2247 Location: Near Monmouth
From recall ? The round part is a base for the “reeds”so that the nuts/bolts can be done up tightly.
April 7th, 2021, 2:18 pm |
Roger V
Thanks Pete, I see how you have made it now
April 7th, 2021, 9:09 pm |
Roger V
So .... Shamelessly stealing Petes idea .....
I like the reeds, but I didn't like that they didn't have a stop and could be over stressed. So designed a fixing and stop plate combined.
Prototype is printed in ABS, which I would be very surprised if it survived the heat. This is in it's infancy, so don't hold your breath. Thinking of perhaps creating a mould from this and could either be created in white metal, or a heat resistant epoxy.
Thoughts please .....
April 8th, 2021, 7:09 pm |
subarupete
What temp does the printer run at? Don’t think the breather gets very hot? Will run my engine and measure with IR gun....
April 8th, 2021, 8:34 pm |
Roger V
Would be good if you could get a IR reading.  Its also how hot oil gets when sprayed on it though. Probably warmer on the inside than the outside. And how much the oil being hot effects the ABS. Edit I print at 230*c, but I don't know how much I trust it over 85c when under load.
April 8th, 2021, 9:40 pm |
subarupete
Ran the engine till the block at 50deg C oil with oil filter at 80deg C, breather at a cool 21deg C. On the move it’s in the air flow, so I reckon it does get that hot, so ABS is ok from a heat perspective but Oil mist may attack it? Test bed available...
April 9th, 2021, 11:03 am |
Roger V
Lets see how far I get with it ....  Pete, what did you do regarding the seal between the two halves?
April 9th, 2021, 2:24 pm |
Users browsing this forum: No registered users and 42 guests |
