            | Author | Message |
			| AZL57 Firing on two.
   |   Re: '85 CharlestonFilled up the 57 last week in germany, some 7 litres used till now.
			| April 4th, 2020, 10:19 pm |
			| rob massey55 Firing on two.
   |   Re: '85 Charlestonfinally got around to servicing it.  P1030123  by Robndaisy , on Flickr Flaming camera's gone back to the black and white days...or is it me     P1030121  by Robndaisy , on Flickr Which one was from the gearbox?
			| September 13th, 2020, 3:00 pm |
			| subarupete Firing on two.
   |   Re: '85 CharlestonThe grey/black one
			| September 13th, 2020, 3:33 pm |
   |   Re: '85 CharlestonI see what you did there
			| September 13th, 2020, 4:17 pm |
   |   Re: '85 Charlestonwhat you needed the torch for? To burn the colour from the photo.
			| September 14th, 2020, 4:19 pm |
   |   Re: '85 Charleston
			| September 14th, 2020, 8:38 pm |
   |   Re: '85 Charleston  After I'd finished servicing it, Daisy washed it. First time I've ever seen her clean a car and the first time it's been washed since 2013 just before our French trip when I waxed it.
			| September 15th, 2020, 9:59 pm |
   |   Re: '85 Charleston P1030262  by Robndaisy , on Flickr Uh Oh, looks like my servicing schedhule's slipped.  P1030239  by Robndaisy , on Flickr The cylinder's seized, shoes are seized and the bottom studs holding the eccentric adjusters sheared despite my best intentions, (I'll have to get creative to fix those).  Time to remove the rear crossmember and sort out the bearings. First time I've opened all this up since buying the car in 2010. On the plus side, all the snail shoe adjusters work perfectly    .  P1030233  by Robndaisy , on Flickr Argh! the pipe union bolt to the wheel cylinder has corroded to nothing and seized to the copper nickel pipes on both sides. That means two new spiral brake pipes and we all know what fun they are to fit    . Funny thing is, the car braked perfectly as far as I was concerned, not twitchy at all, strange that
			| March 7th, 2021, 2:44 pm |
   |   Re: '85 CharlestonMaybe an option, pull the spirals out a bit and fix the bracket a bit further down the pipe. With a flaring tool refit the bolt? A lot af penetrating oil might help to loosen the nut. Not wd40 but the real stuff. I have sometimes succes with taking the nut firmly in a grip-vise and  tap that with a hammer.
			| March 7th, 2021, 7:40 pm |
   |   Re: '85 Charleston
			| March 7th, 2021, 7:55 pm |
		| Who is online |
		| Users browsing this forum: No registered users and 1063 guests |
	|  | You cannot post new topics in this forum You cannot reply to topics in this forum
