Author |
Ianredspecial
Joined: June 22nd, 2014, 8:09 pm Posts: 1296 Location: Reading, Berks UK
 Re: My Red Special
Yes ditto Roger. To be honest I've had automatic cruise control for years and years, at one point I doubled up on the return spring for the cable but worried it would make the cable less reliable (more prone to breaking) so reverted. I've oiled the pedal pivot believing it to be that but only discovered recently the cable was intermittently the source of the problem. I oiled it (I never oil plastic type materials normally but it became ridiculously stiff and I didn't have synthetic spray to hand.
It was a delight after that but not for long. I did imagine it was probably swollen soft nylon casing.
The new one isn't terribly smooth but i thought it would get smoother with use. I only had a very small amount of silicone spray for bicycle suspension forks so I just moistened the ends with that.
In two minds about lubing it up more with silicone spray. That stuff never seems to last long, and shouldn't metal in hard nylon be OK as is?
November 24th, 2020, 9:42 pm |
Roger V
Joined: March 21st, 2013, 12:04 am Posts: 1634 Location: Exeter, Devon
 Re: My Red Special
Can you improve the routing, and take out any sharp turns?
November 24th, 2020, 9:53 pm |
Ianredspecial
 Re: My Red Special
Great minds think alike, obviously haha. Yes, routed as smoothly as it can be.
They do take an awful lot of heat over the years though don't they. And for all I know, the previous one was original to the car. I've had the car since it was about 7 or 8 years old I think. (How funny is that!)
November 24th, 2020, 10:19 pm |
Roger V
 Re: My Red Special
In my early motorcycle days, if i was lubing a cable, I used to hang it up. Then create a plastercine cup around the top. Fill the cup with oil and leave it over night. often the oil would work its way through. Somewhere though, I have a little clamp that clamps to the outer of the cable, but seals against the inner. Then an arosol can inserts and you press the button.
November 24th, 2020, 10:50 pm |
Ianredspecial
 Re: My Red Special
Oh that little device sounds amazing. Yeah the best result I had with mine when I used oil, I held it up by the disconnected throttle end of the cable and dripped oil in for a while as I pulled the metal inner cable back and forth. And left it kind of propped up like that for a bit. Yeah it was fab, had never been like that before. But yeah it went sticky again. It's fine once removed, moves fine. Maybe iit's jjust when it's warmed up well. .
November 24th, 2020, 11:22 pm |
Ianredspecial
 Re: My Red Special
Drove it to work to check it was all good. I usually cycle. It was so smooth and purry, very happy little car.
November 27th, 2020, 1:01 am |
jasu
Joined: August 8th, 2012, 11:00 am Posts: 501 Location: Korpilahti, Finland
 Re: My Red Special
Cable oiling. Just looked a bunch of old magazines what I got from one neighbour, some "populadr classics", "popular mechanics" etc, and that ad showed there..: Attachment:
Photo from "Frost Auto Restoration Techniques" catalog, from 1992 Wondering does that company still exist, they had a lot of decent tools on their catalog..?
November 27th, 2020, 11:05 am |
subarupete
Joined: March 5th, 2009, 6:23 pm Posts: 2248 Location: Near Monmouth
 Re: My Red Special
November 27th, 2020, 12:48 pm |
Jonathan
 Re: My Red Special
Still sell the same product too, just 3x the price of 1992. https://www.frost.co.uk/hyd-cable-oiler/
November 27th, 2020, 6:41 pm |
Roger V
 Re: My Red Special
I borrowed one of those once, it was messy. https://www.ebay.co.uk/itm/Motorcycle-C ... %3A2334524I have one of these somewhere.  For smaller cables though. Don't know if it would fit the clutch cable.
November 27th, 2020, 11:21 pm |
Users browsing this forum: No registered users and 27 guests |
