View unanswered posts | View active topics It is currently June 19th, 2026, 7:58 am
Reply to topic  [ 183 posts ]  Go to page Previous  1 ... 13, 14, 15, 16, 17, 18, 19  Next
 We have liftoff.....AZU 250 rebuild thread
Post Re: We have liftoff.....AZU 250 rebuild thread
Check you have 12v at the actual head/side lights. If you have, then it must be a ground issue.
October 7th, 2020, 3:00 pm
will check tonight......but odd that horn is still working :?
October 7th, 2020, 4:36 pm
Horn is earthed via fixing nut?
October 7th, 2020, 4:48 pm
Just been back out to garage.......All sorted happy days :)
Battery tray was out for access to back of speedo. to get it out I had loosened the vent....which also included the earth.....EEJIT !
October 7th, 2020, 10:20 pm
:idea:
October 8th, 2020, 7:34 am
Been a while !
dash all back in an nearly finished wiring.......Got my steering wheel cap done today.
Started with a rough cut from some scrap 10mm plate.
Tickle with the grinder and add something for lathe mounting
My mates dad then added a step to fit boss using his 60yr old churchhill lathe. Then then I mounted in my drill, and added some shape with a 40grit flapwheel in the grinder...
November 7th, 2020, 8:07 pm
Good results, like it.
November 7th, 2020, 8:22 pm
:) nice
November 8th, 2020, 9:34 am
Post Non stopping wipers !
Hi folks, got caught in the rain today, wipers started fine, but.......even without switch, they wouldnt stop......
I swapped the dash recently, so assumed I'd got the switch wiring wrong , so I disconnected it,,,,,and they still wiped !
Found a few threads on here but I'm still unclear what i need to do !! Is there an easy guide ??????
(its the older, cheese grater type....)
Cheers !
Gerry
November 21st, 2020, 11:12 pm
Is it one that parks? Or would you expect it to just stop where ever you turned it off?
November 21st, 2020, 11:52 pm
Users browsing this forum: No registered users and 228 guests
