View unanswered posts | View active topics It is currently February 3rd, 2026, 6:34 pm
Reply to topic  [ 348 posts ]  Go to page Previous  1 ... 24, 25, 26, 27, 28, 29, 30 ... 35  Next
 My Beduino
Post Re: My Beduino
So, i tried it yesterday on my way to shop, and the cap came off the water reservoir, and dumped all the water. :D
So, designed a new cap for the reservoir.
The return line is in the cap. The addition of the inner collar, should stop the cap popping off whilst under load from the return pipe.
September 25th, 2020, 9:42 am
Post Re: My Beduino
Your 3D printer was a solution waiting for problems.
Keep up the good work
September 25th, 2020, 12:23 pm
Post Re: My Beduino
Hilarious..
September 25th, 2020, 5:15 pm
Post Re: My Beduino
Trying to get the temperature up on the reducer as much as possible, so added some jubilee clips to the copper coil in the exhaust. Clamped one end, and turned the coil to tighten it against the exhaust pipe, and clamped other end with the clip.
The clamps will also stop the coil chattering against the exhaust pipe. :)
September 26th, 2020, 11:06 pm
Post Re: My Beduino
I have the Shed running in LPG. :D
However, I'm trying to add another sensor to the firmware, and its doing my nuts in! :( :cry:
November 6th, 2020, 7:52 pm
Post Re: My Beduino
It's autumn you should have nuts around this time of year... ;-)
November 7th, 2020, 8:30 pm
Post Re: My Beduino
@azl57
Plenty of nuts about, but i have get it done before i go back to the institution, as they are not much help!
November 7th, 2020, 11:07 pm
Post Re: My Beduino
Fuel Temp Sensor added to software. woo woo :D
Now to move the Inlet Air Temperature sensor as its getting heat sink with the Dyane airbox being over the exhaust.
Its been starting on lpg now as well, after a few cranks. Still needs tweaking though.
Once it starts reliably on lpg, i will see about adding the fuel pump to the petrol side. :)
November 8th, 2020, 10:19 am
Post Re: My Beduino
Moved iat sensor to rubber connector between air filter box and carb. Much more sensible readings at idle now.
I think where the sensor was mounted on the filter box, stopped air passing it at low rpm. But that part of the box was being heated by the exhaust, causing heat soak to the sensor. That in turn caused the ECU to pull fuel and weaken the mixture.
Needs a run and log to confirm. And probably retune. :)
November 11th, 2020, 6:46 pm
Post Re: My Beduino
Quite an improvement I am sure !!!
November 11th, 2020, 8:49 pm
Users browsing this forum: No registered users and 220 guests
