View unanswered posts | View active topics It is currently June 19th, 2026, 2:01 am
Reply to topic  [ 6 posts ]
 Early steering wheel
Post Early steering wheel
Hi Folks,
Does anyone have access to an early steering wheel ?
l would like to know the tube diameter that was used....This style:
August 18th, 2020, 5:28 pm
Post Re: Early steering wheel
I could look for you tomorrow morning, if Fer ( AZL57) is not faster with a reply
August 18th, 2020, 6:24 pm
I have two over here a french and a belgian one. Diametre spokes 18mm, rim 22 mm.
August 18th, 2020, 8:24 pm
:P
August 18th, 2020, 9:03 pm
I do love the simplicity of the original steering wheel. I'd happily have one fitted to my 1988 2CV but I believe the wheel is solidly attached to the column, so it's not quite as straightforward to do a swap. I'd have to remove the column as well as the steering wheel.
August 18th, 2020, 11:51 pm
Thanks Guys !!!
My plan is to have a new rim made but using the same mounting plate as the normal wheel.
My mate has rolled a number of wheels for another mate in the Moggy Minor scene, (a bit more detailed...), using existing, trimmed minor wheels.
His Dad is a retired engineer with a shed full of lathes and mills so the wheel center should be easy !
For me, a slightly smaller diameter wheel will help in the constrained confines of the Van (especially with my current "beer belly" :)
August 19th, 2020, 12:22 am
Users browsing this forum: Google [Bot] and 230 guests
