View unanswered posts | View active topics It is currently April 28th, 2026, 5:29 pm
Reply to topic  [ 183 posts ]  Go to page Previous  1 ... 8, 9, 10, 11, 12, 13, 14 ... 19  Next
 We have liftoff.....AZU 250 rebuild thread
Post Re: We have liftoff.....AZU 250 rebuild thread
you have a wiring loom with one or 2 fuseboxes?
August 15th, 2020, 2:26 pm
Just one fusebox.......4 fuses
August 15th, 2020, 10:10 pm
Moving to 602 means cable accelerator rather than rod.....so new hole needed. Why so complicated at the bulkhead ..... ;) Unreasonably strong spring, complicated locking......grrrrrrr
Took ages.....to fit a single cable !!
August 15th, 2020, 10:21 pm
OK will have look in the factory manuals. P.s. It is not that difficult. If you lay out the wiring loom as it should go. You see the couloured plugs of all items to hook up near the loom. Just connect colour to colour... :mrgreen:
August 15th, 2020, 10:24 pm
yeah......I understand the concept but I think I must be colour blind :D I can't find any mauve or Violet terminations and I see a number of shades of brown !!
My bulbs arrived yesterday so I'll get them installed and work on trial and error basis. Thank goodness my van does not have the electric window/air-con/ABS/traction control optional extras..... :lol: :lol:
August 16th, 2020, 10:10 am
The colours of the wiringloom starts to fade after some years . I had the same problem.
I did it like you now, working on trial and error basis .
Good luck !
August 16th, 2020, 10:41 am
Well i did fin these triple schemes. Could this be the right ones?
August 16th, 2020, 4:23 pm
Cheers, thanks for the diagrams !
Through an elimination process, I managed to get most of it sorted. Still missing fuel gauge an oil warning light but im still looking :)
Todays progress....
https://youtu.be/HTRgds6zg1o
Exhaust blowing everywhere but some other issues to tackle first....
Fairly decent oil leak from right hand bank....seems to be higher up than oil tube seals.....Perforated pushrod tube??? Some inestigation needed.
Also got the brakes bled :)
Still getting there...
Cheers
Gerry
August 16th, 2020, 10:34 pm
fuel gauge is a small yellow connector on the meter there should be a yellow dot of paint And the same for the purple one. On the tank there must also be a mass wire otherwise it 'won't work. There is also an mass wire on the complete speedo cluster.
August 16th, 2020, 10:45 pm
Well.......stripped a million fixings from all of the front shroud and the bottom cylinder cowling so I could check the oil feed and the pushrod tubes.....
Oil feeds all dry if a little rusty. Cleaned up all of the residual mess and fired the engine up. The problem was immediately apparent, a holed pushrod tube :(
Some reading in the forums suggest a number of options:
1 replacement
2 aluminium welding/brazing rods
3 Chemical metal
4 Rubber patch and jubilee clip
Since first two options involve head removal, I think I'm going to go with either 3 or 4 for the moment so that I can get the van on the road for the remainder of the summer and tackle the head in the winter.....
Any preferences for option 3 or 4 ??
August 17th, 2020, 11:31 pm
Users browsing this forum: No registered users and 120 guests
