View unanswered posts | View active topics It is currently April 30th, 2026, 2:37 pm
Reply to topic  [ 6 posts ]
 Ecas/Burton Brake adjuster kit Rear
Post Ecas/Burton Brake adjuster kit Rear
Anyone tell me in what order all of the bits should be assembled????
I get the M4/snail cam/spacer inside the drum but what about the cupped washers? This way, () or this way )( and where in relation to the backplate??
One inside and one outside Like this,
Inside ( backplate )
or
inside () Backplate
or
Inside backplate ()
I'm confused.......
July 31st, 2020, 6:54 pm
Post Re: Ecas/Burton Brake adjuster kit Rear
Any pictures? Or is it only me who is not able to see them ?
August 1st, 2020, 7:14 am
I am confused too without the pics :o :o
August 1st, 2020, 8:43 am
From Haynes book..:
August 1st, 2020, 9:25 am
so the 2 spring discs in the same position, mine were rather stuck this week when i had to adjust the brakes. Lucky i had a 50cm long socket wrench handle...
August 2nd, 2020, 11:29 pm
All sorted ...thanks all !
August 3rd, 2020, 7:32 am
