AZL57
 Re: AZL 1957
And not to mention the doors are filled with glass wool... I did see yesterday the battery was low 10 volts. Driving home 3 kms wasn't eough to charge the battery as i started it with the cables before. So it ook t he it out and hooked the old charger up. This morning it had just over 13,7 volts. Started the car and did see the charge go to 16 volts. A bit much, but after a spin through the town it was back to 14,5 volts...Strange.
| July 29th, 2020, 5:43 pm |
Roger V
 Re: AZL 1957
Perhaps take look at the regulator? Ground is the usual suspect.
| July 29th, 2020, 5:50 pm |
AZL57
 Re: AZL 1957
Could be, it stood still for almost 11 months.
| July 29th, 2020, 6:52 pm |
AZL57
 Re: AZL 1957
It started well after 2 days rest. Brakes felt a bit spongy so this morning i started with adjusting the rear brakes and to my surprise there was rather lot of play. I drove 2 summers with 3 persons in the car in very hilly terrain. That must have used the rear brakes a bit. Before i drove it mostly alone and in 37 years i adjusted the rears maybe 2 times...  Now they are fine again.
| July 31st, 2020, 12:45 pm |
AZL57
 Re: AZL 1957
It was 44 degrees in the car. On the way home it past the 220000 km mark.
| August 6th, 2020, 4:42 pm |
AZL57
 Re: AZL 1957
My 83 2cv didn't start just at work. This morning it was already difficult. I hit the startermotor with the starting handle (that is wat it was made for?)and it did run again. So i think it will need new brushes. I swapped the motor and did find that the one i put in now was the original one. It was already cleaned and prepaired.
| August 10th, 2020, 6:05 pm |
AZL57
 Re: AZL 1957
Other nice surprise today, i did find one of the last types of miners lamps used in our local coal mines. It has an electric ignition, very rare.
| August 10th, 2020, 10:28 pm |
AZL57
 Re: AZL 1957
This morning no starting, i think the battery is dead it had only 10 volts left. Will have a look for another tomorrow.
| August 12th, 2020, 4:54 pm |
AZL57
 Re: AZL 1957
Did let the battery test it was confirmed dead... So i put in a new one if i am correct it is the 4th battery in this car.. a Austrian one this time...
| August 13th, 2020, 5:22 pm |
AZL57
 Re: AZL 1957
Here an old picture i took of my green 57 during a holliday in france at 6 in the morning.
| October 11th, 2020, 5:56 pm |
Users browsing this forum: No registered users and 106 guests |
