View unanswered posts | View active topics It is currently May 8th, 2026, 4:46 am
Reply to topic  [ 993 posts ]  Go to page Previous  1 ... 46, 47, 48, 49, 50, 51, 52 ... 100  Next
 AZL 1957
Post Re: AZL 1957
The glass on the roof is 3 layers and you can walk on it. I will have go with a magnet ;-)
@Eirik: I think you are right, i did try this morning so most of the play is in the middle on the steering housing.
July 3rd, 2020, 4:54 pm
Post Re: AZL 1957
Is i have my holyday now i have time to have a go at the steering. I had to go and buy an other puller for the steering arms as my Facom model couldn't fit as the gearbox in it's place. After 3 tries between showers i got all off. All 4 parts had lot's of wear. Together it was a lot. Bronze block were worn on some edges due to the bend sliding plate that let them slant. The top mounting plate had its edges bend by the steering pins. So the wheel stops might have to be adjusted...
July 10th, 2020, 4:09 pm
Post Re: AZL 1957
Emergancy break..
July 11th, 2020, 12:45 am
Post Re: AZL 1957
:lol:
July 11th, 2020, 9:46 am
Post Re: AZL 1957
I think it a mimic of the Mercedes F1 tow in to warm up the tyres. The steering being out of the car is a sure indicator of this. :D
July 11th, 2020, 10:15 am
Post Re: AZL 1957
Hilarious..
July 11th, 2020, 12:37 pm
Post Re: AZL 1957
Mercedes would wish to have such a steering unit....
July 11th, 2020, 3:51 pm
Post Re: AZL 1957
It's also a womenish attitude when riding a bicycle :D :D :lol:
July 11th, 2020, 5:28 pm
Post Re: AZL 1957
I thought : I know that squint-eyed face .
Now I know :
https://www.imdb.com/title/tt0626009/me ... m910642432
July 13th, 2020, 7:53 am
Post Re: AZL 1957
Well the car is back together again. It took me 1,5 hours to put 6 bolts and 2 nuts in. It turned out that a end of the steering pins was bent. So it turned around when i tried to put the castled nut on. With the help of a thread cutter, a thread file and some brute force i got the nut on. The bronze blocks are now pushed down with the modern rubber block in stead of the little spiral springs. Will have a test drive later as i am knackered from the heat... ;-)
July 13th, 2020, 4:19 pm
Users browsing this forum: No registered users and 244 guests
