View unanswered posts | View active topics It is currently November 19th, 2025, 10:36 am
 component inside indicator unit.
Post component inside indicator unit.
Hi all,
About to change broken indicator unit and have noticed in the replacement there is an extra component inside.
In the broken one there is just an empty space.
Does anyone know what it is?
Thanks in advance.
July 9th, 2020, 8:33 pm
Post Re: component inside indicator unit.
Is it wired?
Could be a buzzer reminder.
I've Been Wrong Before.
July 9th, 2020, 9:05 pm
That's a clacker isn't it?
Earlier switches had a clacker built in. I fitted one to mine to stop the other half forgetting to switch the blinkers off. They're absolutely excellent.
Fit it and enjoy.
July 9th, 2020, 9:59 pm
Thanks for that, I shall enjoy the extra noise!
July 9th, 2020, 10:52 pm
That is the clacker , it is magnificent . I have it in my 1974 2CV van .
Love it !
July 10th, 2020, 7:59 am
Indeed, when the indicator relais is not noisy enough, in my case I have an very silent electronic blinkerrelais for LED's, such a clacker is an excellent solution. Never seen before, but where to get ?.
July 10th, 2020, 9:14 am
I had one in an grey indicator switch. But i cut the wires because i think it damaged my clignoteur??
July 10th, 2020, 9:20 pm
You mean it damaged the indicator relais ?
July 11th, 2020, 3:55 pm
From almost any 70's era 2CV/Dyane..?
But. I'm pretty sure, it won't work with LED indicators, because the clacker get earth from "the other side" indicators and LED doesn't flow current enough for clacker. Maybe I'm wrong, someone needs to test that...
July 11th, 2020, 5:03 pm
I think you are right Jasu, too low current for the clacker :mrgreen:
July 11th, 2020, 5:25 pm
Users browsing this forum: No registered users and 23 guests
