Author |
rob massey55
Joined: December 21st, 2014, 7:33 pm Posts: 877 Location: Rhayader Mid Wales
 Re: Yellow Dyane
July 3rd, 2020, 9:03 pm |
Geert
Joined: July 10th, 2010, 12:35 pm Posts: 1174 Location: Magyarország
 Re: Yellow Dyane
that is even worse .
July 4th, 2020, 7:15 am |
rob massey55
 Re: Yellow Dyane
July 4th, 2020, 11:08 am |
Geert
 Re: Yellow Dyane
I did not know this song from Frank
July 4th, 2020, 2:08 pm |
Geert
 Re: Yellow Dyane
Any progress on the yellow Dyane?
October 31st, 2020, 10:15 am |
rob massey55
 Re: Yellow Dyane
Well it's six months since I worked on the car, Daisy returned from Portugal in August and we've been walking the Wales Coast Path every weekend since. Done about 200 miles now and only 685 more to go. Anyway, now we're locked down again and it's been snowing so I got back into the tent, restored electric power, tidied up, it was like the Marie Celeste (without the food) and started on the bodywork again. The bottom edge of the original windscreen panel had rusted away, all of it , so I had no accurate way of knowing what the gap between the flanges should be. The top edge is about 10mm. P1030165 by Robndaisy, on Flickr and the flange on the repair panel varies along it's length but it's more than 10. P1030166 by Robndaisy, on Flickr Now I could just trim the bottom flange/edge down to 10 mm. and trust to luck that's it right, but if it's too small, fitting the windscreen (whenever that'll be) could be very difficult and I don't like difficult. so I asked Ken and the legend that he is, he got straight back with photos he'd taken with a steel rule from an original panel on a bodyshell. The magic number is 393 mm. edge to edge. P1030167 by Robndaisy, on Flickr P1030164 by Robndaisy, on Flickr P1030163 by Robndaisy, on Flickr So quite a bit to come off the lower flange then. That's fine now I know and some repro panels need more work than others as we know. Thanks Ken  All the best for 2021, anyone not having a jab in the arm when it's offered  .
December 29th, 2020, 4:25 pm |
Roger V
Joined: March 21st, 2013, 12:04 am Posts: 1637 Location: Exeter, Devon
 Re: Yellow Dyane
Hey, welcome back Rob  Nice clear pictures please because I need to do the windscreen surround on the Bedouin.
December 29th, 2020, 7:29 pm |
Geert
 Re: Yellow Dyane
rob massey55 wrote: All the best for 2021, anyone not having a jab in the arm when it's offered  . Save them for Doris and the Devils.
December 30th, 2020, 12:51 pm |
rob massey55
 Re: Yellow Dyane
P1030309 by Robndaisy, on Flickr P1030310 by Robndaisy, on Flickr Before I weld in the windscreen repair panel I need to fit the bonnet just to make sure everything will fit as Citroen intended  . These rusted split pins might come out with some help... P1030313 by Robndaisy, on Flickr P1030314 by Robndaisy, on Flickr Phew  I'm going to fit some pins (5+ mm. but not 5.5mm.) made from brass or copper 'n plenty of grease, eventually. P1030315 by Robndaisy, on Flickr A bit 'wonky' but I guess I'll fettle it . P1030318 by Robndaisy, on Flickr I'd forgotten what it's supposed to look like
April 23rd, 2021, 7:18 pm |
EirikJ
 Re: Yellow Dyane
Woop woop! The story continues.
I shouldn't be reading this though. Have felt a big need the last months, to get a Dyane. But the LAST thing I need, is another car.....
April 23rd, 2021, 9:29 pm |
Users browsing this forum: No registered users and 20 guests |
