We have liftoff.....AZU 250 rebuild thread
48pop
Joined: May 23rd, 2011, 7:14 pm Posts: 309 Location: ecosse
 Re: We have liftoff.....
yep, that was my decision ..... L shaped bracket, drill one hole, job done !
| May 12th, 2020, 11:03 am |
48pop
Dagmars ?? Painted shells, got lots of runs, will be redoing !
| May 19th, 2020, 5:45 pm |
Roger V
Thats a nice colour
| May 19th, 2020, 7:24 pm |
48pop
| June 1st, 2020, 12:59 pm |
48pop
Just checking.....
Front drums, is it utterly impossible to get the "3 way to drum" brake pipe fitted when the slave cylinder is fitted?
Another question, is it only possible to to assemble the front brakes if you have 3 arms?
I've got a Dyane box here and there is plenty of space between the gearbox casing and backplate but on the 602 box.....its very tight !
| June 7th, 2020, 11:14 pm |
Geert
Joined: July 10th, 2010, 12:35 pm Posts: 1205 Location: Magyarország
48pop wrote: Just checking.....
It is possible, I have done it once, but it is not advisable. You need very thin fingers and a lot of patience. What I can advise is: Adjust the brake shoe adjustment lugs so that the cylinder is exposed, so you can easily remove the cylinder and leave the brake shoes. After mounting the cylinders you can adjust the brake shoes again. Piece of cake. Quote: Another question, is it only possible to to assemble the front brakes if you have 3 arms? No, two good arms will do.One left and one right .
| June 8th, 2020, 8:19 am |
AZL57
It helps if you have an pet octopus
| June 9th, 2020, 6:14 pm |
48pop
Some more small tasks complete... Originals media blasted, primered and sprayed.....  Headlamp bar Shortened, blasted and painted
| June 14th, 2020, 11:53 pm |
AZL57
Looks great.
| June 15th, 2020, 8:05 pm |
Edce
Joined: October 12th, 2019, 6:40 pm Posts: 164 Location: Limburg Belgium
Headlamp bracket shortened ? What was the reason and where did you shorten it ? Thnks
| June 15th, 2020, 8:41 pm |
Users browsing this forum: No registered users and 205 guests |
