View unanswered posts | View active topics It is currently June 19th, 2026, 4:00 am
Reply to topic  [ 1048 posts ]  Go to page Previous  1 ... 95, 96, 97, 98, 99, 100, 101 ... 105  Next
 Make Your Own ....2CV.... 4x4
Post Re: �Make Your Own ....2CV.... 4x4
subarupete wrote:
Wow views of 127203, sadly 50% are probably "bots".
Well keep the posts comming then...
April 16th, 2020, 12:10 pm
Road car is ready to MOT---- Steering done, new carb (emissions were Bad), lights fixed.
But MOT's hold for non essential cars etc.
So some updates soon on the 4x4
April 16th, 2020, 1:54 pm
Good luck !!!
April 16th, 2020, 8:02 pm
The saga begins..
The transfer box/Diff problem, (I think !?).
The solution.....
April 19th, 2020, 4:20 pm
Engine and box out, rear gears dismantled, appear to be well lubricated....
April 22nd, 2020, 2:30 pm
The whole saga began.
Test drove the car, up the road and round the field.
All went well...
Let the car stand for about 5 weeks + started the car , nasty sound from gearbox, push the clutch to the floor, noise stopped, let clutch up noise come back.
ASSUMED it was the input shaft bearing!!!
Have examined the clutch housing, it was clean when it got assembled and had been used before.
The bell housing has some black dust and some aluminuim filings???
Will look at clutch and release bearing.
The saga continues, took the box apart, all the bearings have oil and so no signs of running dry?
But have modified the box anyway...
Before modification.
Modified box
April 23rd, 2020, 5:23 pm
Progess today....
April 24th, 2020, 3:36 pm
Another modification/addition.
April 25th, 2020, 5:38 pm
You're into the world of the sublime Pete :)
Good stuff!
April 25th, 2020, 5:56 pm
While I have the engine and box out, I am trying to see if I can move the struts.
Currently even with softer springs the front is too hard.
Move the strut bottom mount to miss the steering and fit under the bonnet, needs some carful measurements!!
Short bottom mount.
Pivot point to miss the steering tie rod?
Yellow line is the sweet spot.
April 26th, 2020, 2:23 pm
