View unanswered posts | View active topics It is currently June 19th, 2026, 7:44 am
Reply to topic  [ 183 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8 ... 19  Next
 We have liftoff.....AZU 250 rebuild thread
Post Re: We have liftoff.....
suspension cans on an AZU250 are t
April 5th, 2020, 7:49 pm
suspension cans on an AZU250 are the same as a car
April 5th, 2020, 7:52 pm
There's something in the water tonight, so that might be why. But I cant make any sense of the last two posts.... cheers guys!
Vennlig hilsen, Eirik
And a Heinemann Z412 -80
April 5th, 2020, 11:46 pm
Soo, busy weekend, painting and cleaning....
Drum assembly removed and cleaned up, ready for transfer to the "new" box, (which originally had disks....). Did a big order tonight including new shoes etc, original Wheel cylinders were like new, obviously recently replaced.
2 days of cleaning, followed by some paint....freed off track adjusters and castle nuts
Are these cans terminal??? seems to be a very thin plate attached to the can ends......cans are otherwise solid
April 6th, 2020, 12:57 am
You should take at least one of the caps of by grinding the weld of from the front side.
The caps are available from Ecas or any other 2CV shop.
If the inside is clean and rustfree , the cans are oke.
In my case one of the springs inside was broken, but the whole inside was also covered in grease.
You should apply Rhicinus oil , no grease , after you have installed the spring cans again to the vehicle, turn the cans , so that the oil is evenly spread.
April 6th, 2020, 7:41 am
Ricinus oil = castor oil. But I think I have seen it suggested that colza oil (= rapeseed oil) is just as effective and probably a lot cheaper.
Dennis usually in the Cantal
1982 Red Special - RHD
April 7th, 2020, 10:00 pm
That is correct it is the trade name of the product.
I do not know if rapeseed oil ( colza oil) is evenly efficient, but as it is both of vegetable origin, I guess it would not make any difference .
April 8th, 2020, 8:26 am
So got some time in project today......cleanup and a splash of paint for new gearbox.
Got the backplates swapped over for the drums and took the wheel cylinders apart to check.
Then I spent a happy few hours with gaiters.......the middle gaiters must have been designed by a psychopath who was having a bad day...the most awkward, annoying and slippery things I ever had to handle. To make matters worse, I found a tear on the one I thought was reusable :roll: :roll:
Even the new rubber bobbins for the gear-change were a pain to fit :(
I swear this is my last ever project !!
Track rod end rubbers tomorrow................. :shock: :shock:
April 11th, 2020, 7:55 pm
Did I lend you my Workmate ? ;)
April 12th, 2020, 7:37 am
:D That wee bench has been around for a while ...In fact I lubed all the pivot points yesterday so probably another 20 years in it !
April 12th, 2020, 10:56 am
Users browsing this forum: No registered users and 229 guests
